Build Threads Details on Club Lexus SC owner vehicles
2jzge na-t build ?'s
Old 12-24-11, 06:37 PM
2JTsc300
2JTsc300's Avatar
Default 2jzge na-t build ?'s
im looking for injectors. for what i hear the factory ones are high impedance. is that correct?
if i get 550cc high impedance i wont need the resistor box right?
Old 12-24-11, 06:47 PM
Wicked SC
Wicked SC's Avatar
The USDM 550cc injectors are low impedance so they require a resistor box..
Old 12-24-11, 07:21 PM
nivek5sfe
nivek5sfe's Avatar
if you really want 550cc injectors rx7 injectors are 550cc and drop in without a resistor box.
Old 12-24-11, 09:07 PM
Ali SC3
Ali SC3's Avatar
yes, high impedance means you do not need a resistor box because the ecu is looking for high impedance.
low impedance injectors require the resistor box to be wired in.
also na-t uses top feed, 2jzgte uses side feed so they will not work for na-t.
Old 12-26-11, 07:17 AM
2JTsc300
2JTsc300's Avatar
ok im goin to get 550 high impedance top feed to drop in there
97NaSupra
SC400 / 300 Classifieds
10-14-13 07:48 AM
98$c300
10-26-12 09:37 PM
Sk8tehwake
13
02-21-12 01:57 PM
onejapman
SC- 1st Gen (1992-2000)
04-13-11 05:49 AM
Quick Reply: 2jzge na-t build ?'s
