Redid the amp rack mounting. Bought a riv nut kit and replaced how I did the mounting. It's a lot better now. Also added a brace at the changer that bolts to tail light nut to keep everything from moving. Nothing going anywhere. Removed mount for the jack and made a template for the mount for the battery, circuit breaker and voltage gauge. Lot's of progress today.
I wish I had time. I only get a couple of hours here and there to work on it. It's fine though since when it's finished I'll have to find something else to do. You don't need my help, your car is looking great with just you working on it. Plus, I'm getting old, this car is killing my back.
Did some work on the battery plate. Cut the birch and attached the supports to the fender. Everything as level as can be. Cut the vent box down to clear everything. It will still vent when I get done.
