Project: clean up...wut?
#31
thank you, the front lip came in, as well as the stock turbos
monday- springs,dp,exhaust cf wrap should all be here.
starting to tear down the car for the stock turbo swap this weekend. hopefully i have it done by monday, so can start getting the exhaust fabbed up,
#33
turbos out, manifolds where also pulled, but i didnt get a pic. awaiting the single turbo kit to come in .
also wrapped the front lip the best i could with ****ty wrap i got in from ebay. half of the wrap wasnt use able so i have to peaice it together, its fine for now , i will rewrap it or paint it down the road.
#36
climate control, replaced, bought a used unit, swapped new lights into it, good to go, old one was 100 blacked out by bleeding led screen
now onto gauges, i have a boost guage and a wideband, the boost guage is hidden in the glove box, not sure if i want to stick with that and stick the wideband in there as well, i normlly like ot be able to see it infront of me at all time, but i really want the thing hidden. your thoughts ?
#39
taken during the test fit of the mani, so don't mind the coolant lines. new flange welded on, coolant lines capped, oil lines being mad, becuase the ones i got where wayyy to long. more pics to come. didn't take many sorry
#43
before you think you know everything, seach. my stealth/3000gt is on 15g turbos which have broke 500whp more then a handle full of times. and the highest awhp on a 9b was 401. which was the same car that went 10.90s stock engine stock head, stock turbos, lightweight and highly modded. but anyways my stealth is on a 15g not a 9b turbo. but thanks for ripping on my stealth there guy.
#44
#45
