2jzGTE SCs - The Siblings of my Supra MKIV Toys
#1594
#1596
yeap the drager II is 95mm .. just a tad smaller than 4" . You might want to insert the extension so in the future ,if you want to change your exhaust you can still sell that exhaust to the supra guys . Am sure you would love the exhaust note coming from that drager II. I just hate the size of the canister being huge but I love the sound it emits.
#1597
Gerrb buddy, I believe I ran across a headlight resto here on CL I believe member JWIN had restored his with sanding them down and buffing them out with a plastic polish product. Hope it helps.
#1599
^^^^ you have a few ways to do it. I have seen some that after you sand all the yellowing off and move up to fine grit you spray it with a poly clear. I just wet sand from 1000 up to 6000 grit and then polish with plastic polish. The poly clear will probably protect the headlight and last longer.
#1600
Jimmy - you better tuck that HKS Super Drager II of yours well. Coming from a 30 degree incline to a flat surface, I get the bottom tip of my exhaust canister scraping . I really need the wider / bigger tires installed to get that rear higher off the ground.
#1603
Today I had some free time and decided to mess around with the fenders that I pulled. Wanted to make them look like stock and take out all those small creases caused by the the pulling and pushing . Applied body filler and will eventually sand them down . I am seriously considering the Mickety Thompson ET Street Radial 28x13.50x15 and I believe with the pull , they will fit without any problem.
#1604
Nice work so far, man! I've got a red 1994 SC300, currently in Coweta County, GA and I've got some similar goals as to what you've done so far, just with some Getrag goodness and Turbo in the works
#1605
1JZ Single SC400
Jerry I was wondering, who is going to paint this car? You have done almost the entire car yourself, why not the paint also? If you have another power antenna lying around I need one. The one I bought from Aliga, broke. I hear the motor but no movement on the antenna, needs a mask.
I cant wait to see this red one complete and take a ride in it. Oh wait a minute, I mean drive it!!!
