2jzGTE SCs - The Siblings of my Supra MKIV Toys
#2297
Well, today , forced myself to do some work on the RM2... decided to paint my extra fuel tank which I will use since it was bare metal and paint will help avoid any corrosion / rusts for which some surface rust had started to build
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140512_104314_zps8b281603.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140512_104407_zpsaa6e00d6.jpg)
Aaron came over to my place and decided that he didn't want the 4" downpipe and midpipe so we did swap with my 3" downpipe / midpipe which came from Jay's car through Mark. So I wil get an extension for that midpipe so I can get it v-banded on the dual exhaust also from Jay.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140512_115324_zpse53c3a42.jpg)
#2298
Red Mamba 2 currently has the Supra NA 9" wheels on the rear with 245x50x16. Traction is always the problem on cars with good HP when you don't have the right tires setup.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_114730_zps4b417c03.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_114759_zpse6c60e9e.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_114809_zpsf0b3a890.jpg)
In a little bit I will head to the tire shop and get the Mickey Thompson Street ET II 295x50x16 installed and see how RM2 would look like.... got to have traction to put that power down !!!
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_114843_zpsc2016b15.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_114834_zps9c686d5c.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_115834_zps1224af92.jpg)
#2302
Well, I can experiment on the looks later
#2304
So how is your car running ? Everything good now ?
#2305
I still have no idea what to do about speedometer or odometer.....I am going to buy the VSS Marlin Crawler Speed Sensor and see if it works then...
#2306
Yep everything is good so far....my 4" piece of aluminum pipe should be here tomorrow so I can make and intake out of it....and just finishing up the door panels....
Front of the car should go down another 4 inches once the built engine is in . Anyone needs Toyo R888 315 tires you see in the picture ? I can barter and I need 2 Nitto NT555r or MT ET II DR size 305/45R18 . The R888 has less than 100 miles.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_193605_zpsd9636605.jpg)
I will take out the stock sc300 catback / mufflers today and install the dual 3" catback I got from Jay and get the V-band so it can be mated to the 4" midpipe .
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140513_185630_zps88b08019.jpg)
#2309
I like how you threw radials on the stock supra rims. I have tt supra wheels the 17 inch ones and wanted to do the same thing as I have a nice set of potenzas on my street rims
#2310
Today I did take Red Mamba 1 for a spin and was surprised when I tried firing my nitrous on the top end , the nitrous system , didn't fire. I have checked the Pro-EFI data logs and my fuel pressure to the fuel solenoid was lower than my required pressure to set the nitrous going...
Currently, fuel solenoid is getting supply after the fuel rail and on the other side of the regulator. So I decided to cap that end and get my solenoid fuel supply directly from the -10an line coming from the weldon 2345a pump .
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140522_185021_zps172e61d3.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140522_184948_zps5c48fab2.jpg)
Will do some modification on my fuel supply by using a fuel log .. 2 x -10 goes on each side of the fuel rail and the 1 x -6 goes directly to the fuel solenoid.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20140522_190115_zps78829e1c.jpg)
