2jzGTE SCs - The Siblings of my Supra MKIV Toys
#2551
As I said, for Red Mamba TWO engine bay theme will be different shades of black on a semi shaved RED engine bay with no ABS, relocated Fusebox and battery and will try to hide all wiring as much as I can.
I didn't want to ruin the chromed valve covers that are on the engine I am installing on the Red Mamba TWO so I bought a set locally through Craigs.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141213_170056_zps0a7abe9f.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141213_170109_zps953fde34.jpg)
Sanded them down. Drilled the 3/8 hole with 45/64 so I can tap both valve covers with 1/2 -14 NPT for the catch can
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141214_140622_zps66fbf88f.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141214_140635_zps6f657a9b.jpg)
#2552
Painted them wrink;le black and cured them for around 30 min on the oven while my wife wasn't around
. Cleaned the oven otherwise I will be in deep **** if she knows I used her oven for something for my cars. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141215_133819_zps844a5639.jpg)
After the curing ... damn these look good, exceeded my expectations. Am trying not to spend a lot on cosmetics so I am doing the work myself instead of getting them powder coated by the professionals. I would rather spend the money on go fast goodies. Heck $10 of VHT wrinkle plus and probably used only half of it compared to $100 if I got them done.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141215_133858_zps84140aed.jpg)
#2553
Red Mamba TWO engine bay will look sweet once done. I am waiting for some Chrome Acura Bolts from my buddy Dennis (Jeslet) which I will use on that coil and valve covers to put some accent on the engine bay since it will all be different shades of black with a red bay.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141215_134233_zps9b434ea6.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141215_134155_zpsfcbb1b0d.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141215_134219_zps2b6c0b46.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141215_134244_zps4aafad27.jpg)
#2556
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/dboy_zpsac50be44.jpg)
Can't wait for them man. I just have to finish my engine bay so I can drop the drive train in.
#2558
Here is the build thread on SF for that car that belongs to d_boy.
http://www.supraforums.com/forum/sho...ght-the-wrongs.
Shaved red engine bay will really stand out if every thing on the bay has a dark color shade
I am about to paint my catch can and brake booster a glossy black just like the coil cover and shroud.
#2560
Thanks pare !
#2562
i may have sourced a non-vvti engine out in cali, and it has the auto trans for ya!
i'll be going the non vvti route. do you have any tips for me on what to inspect when the motor arrives?
i actually want to request a video of what the cylinder walls look like... tell them to take the spark plug off, and stick a boroscope in there.
#2563
I doubt if they will stick a boroscope in there to see cylinder conditions. If they can give you compression or better yet leak down numbers, then you will have at least an idea of the engine's health.
When it arrives, confirm the compression & leak down numbers by doing your own tests. Once you disassemble that engine, your warranty is probably gone. Buying JDM engines is a hit and miss thing . While it is out , you might want to replace some things anyway like oil pump , water pump and head gasket..... all ARP hardware (mains, rods , headstuds) so it will be ready for more boost. Replacing the valve seals would be a good idea since startup smoke is common to 2jz with some mileage.
#2564
Picked up two Auto TT Transmissions
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141218_170403_zps0c3874c0.jpg)
And sent them out for Stage 3 Build . My Red Mamba ATF transmission had been holding up really well so decided it will be better to have these two other rebuilt while the build prices are still good. A little bird told me that prices for rebuilding these with a billet 2nd gear sprag will go up since there are more and more getting them done.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141218_120146_zps1a4d7032.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141218_120219_zps210c61a8.jpg)
After I went to Summitracing to buy some stuff for my builds and there was a nice toy on display right infront ..
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141218_122900_zps3572207d.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141218_122810_zps354f9b50.jpg)
#2565
I received the chrome bolts from Dennis in the mail. They will be good accent on a black engine bay.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141227_135321_zpsd2ebc3bd.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141227_135355_zps9abc2dc4.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141227_135422_zps1c478167.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141227_135506_zps62bf8d67.jpg)
It is cold out there. But I found a good place to paint parts of my engine where it is warm and toasty... a bathroom that is not being used. Here I am painting the upper coolant elbow with wrinkle black and my IACV with high temp flat black.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141227_172802_zps726a8a3e.jpg)
Damn I couldn't bake the upper coolant pipe so decided to put it near a heater vent so wrinkle paint will cure well and still came out good.
![](http://i1010.photobucket.com/albums/af227/gerrb/2ndSC4002jzgteProject/20141227_222846_zps74c8c31f.jpg)
