Build Threads Details on Club Lexus SC owner vehicles
2jzGTE SCs - The Siblings of my Supra MKIV Toys
Old 01-20-15, 06:24 PM
  #2641
SC2JZ300
SC2JZ300's Avatar
Good to see you took the jump for laying down paint. Looks good for a diy'er
Old 01-21-15, 03:29 AM
  #2642
gerrb
Super Moderator
gerrb's Avatar
Originally Posted by CatManD3W
Looks good man.....Cant wait to see the engine back in there!!!!
Originally Posted by lexforlife
Simply outstanding work bro, keep the pictures coming
Thank you guys .
I figured learning how to paint will help me save tons. I will try painting Red Mamba One after winter. The hard part is body preparation... applying putty then sanding using the right grit of sandpaper. It is a tedious process you do over and over again till all flaws are covered.The actual painting itself isn't that hard once you have the right paint mixture and you get to learn how to use your equipments so you avoid runs , orange peels , etc. . Practice is the best teacher here. You get better as you go along.
When I try to do something for which is not my field of expertise or not what I went to school for , my attitude is always "If they can do it, I can do it !" That motivates me a lot to succeed .
Old 01-21-15, 06:39 AM
  #2643
gerrb
Super Moderator
gerrb's Avatar
Started taking out the tape I used for masking and re-assembly starts. I was originally planning to use new brake lines but decided to use the original ones so started bolting the line with retainers. I took out the ABS . The front passenger brake line goes directly to the brake master cylinder T'ed with the driver front brake line.
Before I re-install the AC lines I will paint it black together with that strut bar
Old 01-21-15, 07:52 AM
  #2644
gerrb
Super Moderator
gerrb's Avatar
AC Lines and Strut Bar Painted
Old 01-21-15, 09:03 AM
  #2645
gerrb
Super Moderator
gerrb's Avatar
It is slowly getting there. AC line is in place .
[URL=http://s1010.photobucket.com/user/gerrb/media/2ndSC4002jzgteProject/20150121_113932_zps75d042f6.jpg.html][/URL
Old 01-21-15, 09:15 AM
  #2646
8052JZ
8052JZ's Avatar
Starting to fall in love with this color gerry!!! Awesome work!!
Old 01-21-15, 09:52 AM
  #2647
gerrb
Super Moderator
gerrb's Avatar
Same here Richard . Looks like I will like it better than the bling bling engine bay . It is lot easier to maintain / clean and paint is cheaper than chrome. It remains to be seen.
Was imagining how it will all look like once engine is in with different shades of black.. shiny black , flat / satin black and wrinkled black
Old 01-21-15, 10:32 AM
  #2648
gerrb
Super Moderator
gerrb's Avatar
Test fitted radiator / cover ... they both need to be cleaned and painted flat black . Radiator Shroud will remain shiny black
Now I need to re drill the hole where the catch can will be bolted . I accidentally filled it with bondo . Scratched up catch can need to be painted too.
Old 01-21-15, 12:45 PM
  #2649
gerrb
Super Moderator
gerrb's Avatar
Sprayed catch can with pimer
Painted the radiator holder shiny black . I have decided to use wrinkle black on the catch can since my valve covers are wrinkle black and the -10AN lines are black braided lines. I am still try to get it dried here and eventually paint starts wrinkling up
Have cleaned the radiator and will keep the top stock color ... no paint
Installed the AC condenser which I painted high temp flat black
Old 01-21-15, 01:26 PM
  #2650
PoGikoSc4
PoGikoSc4's Avatar
Amazing progress Mang Gerry. That last coat of clear made it even better and gave that glassy look. Kept looking at those pics last night you text me lol. I'm next in line for a fully body work, paint and details, for a fee of course. Cant wait for the warm weather for sure.
Old 01-21-15, 01:39 PM
  #2651
gerrb
Super Moderator
gerrb's Avatar
I didn't post those pictures I sent you last night. I don't know why they don't come out well on the laptop monitor . The cell pictures do better justice on how the engine bay looks ... which is glassy or wet.
Heck No I am not painting anyone's car . I hate the body work / sanding part... spraying paint is easy once you get the hang of it. You sand and do the body work.. I will spray it for you .. hahaha.
I can't bolt the catch can in place for now..... got to wait 24 hours to cure the wrinkle / paint . A question for those who knows... does wrinkle paint works on plastic ? I was thinking of painting the top of the radiator with wrinkle black.
Radiator is at least clean now ..
Old 01-21-15, 02:49 PM
  #2652
gerrb
Super Moderator
gerrb's Avatar
Can't wait for tomorrow ... lol . Decided to bolt my catch can carefully
Old 01-21-15, 05:23 PM
  #2653
lilSCsteve
lilSCsteve's Avatar
All I can say is WOW! Keep the updates coming!
Old 01-22-15, 05:28 AM
  #2654
irondonkey
irondonkey's Avatar
isnt the rad a little bit too small for your setup?
Old 01-22-15, 05:37 AM
  #2655
gerrb
Super Moderator
gerrb's Avatar
thanks buddy !
For now it will do the work. It is a run around town car for me, 350rwhp. It will be a stock setup to start with. In town, I wont even use that power too...probably a mile burst every now and then, so I don't like to spend more money than necessary . The radiator is like new and came with the car already. Once I go higher boost and more power on this car then an upgrade for the radiator will be necessary. Probably will never happen since I will have other high HP SCs.
Quick Reply: 2jzGTE SCs - The Siblings of my Supra MKIV Toys
