2jzGTE SCs - The Siblings of my Supra MKIV Toys
#2716
Super Moderator
Gauge Cluster Conversion
To make it easier to know which wire from the 97 goes to which wire on the 92, let us start making a table so it is easier for others who can't read wiring diagrams to follow.
Since I am not taking out the old 92 plugs , I will just solder the wires from the new cluster to the corresponding wire on the old cluster so I can use either gauge clusters. Though you will do less soldering and repinning if you just replace the old 92 plugs with the 97 plugs .
First lets take a picture of each plug we will use so it will be easier to follow . As I have shown and said on the "2jzgte Wiring Harness Made Easy" thread, numbering of pins usually start on the left of the plug with the plug lock on top. I have also shown on that thread how to pry a pin out so check it out if you don't know how to . I don't feel like repeating that info here. But let me give you the link again of that thread -> https://www.clublexus.com/forums/per...made-easy.html
92 Cluster Plugs
Plug A
Plug B
Plug C
97 Cluster Plugs
Plug A
Plug B
Plug C
Plug D
92 Cluster Plugs
Plug A
Plug B
Plug C
97 Cluster Plugs
Plug A
Plug B
Plug C
Plug D
#2717
Super Moderator
Here is the Table so you know where each wire from the 97 should be soldered on the 92
92 <-> 97 <-> Notes
A1 <-> B6 <-> P - Gauge Cluster Light chk
A2 <-> B7 <-> R - Gauge Cluster Light chk
A3 <-> B8 <-> N - Gauge Cluster Light chk
A4 <-> A10 <-> D - Gauge Cluster Light chk
A5 <-> B9 <-> 2 - Gauge Cluster Light chk
A6 <-> Empty
A7 <-> C9 <-> Seat Belt chk
A8 <-> C16 <-> BU1-4 Fuel chk
A9 <-> Empty
A10 <-> C11 <-> SRS chk
A11 <-> C10 <-> SRS chk
A12 <-> D15 <-> Door Open chk
A13 <-> C8 <-> Brake chk
A14 <-> C13 <-> Charging System chk
A15 <-> C12 <-> Charging System chk
A16 <-> B12 <-> L - Gauge Cluster Light chk
A17 <-> A9 <-> Illumination System / Tail chk
A18 <-> C4 <-> Overdrive ON/OFF chk
A19 <-> C14 <-> Oil chk
A20 <-> C3 <-> Cruise chk
B1 <-> A1 <-> Trac OFF chk
B2 <-> Empty
B3 <-> A4 <-> AC Control Assembly / MILF chk
B4 <-> B13 <-> ECT - PWR chk
B5 <-> A5 <-> Trac chk
B6 <-> B4 <-> High Beam chk
B7 <-> B3 <-> High Beam chk
B8 <-> A8 <-> Oil Level chk
B9 <-> C5 <-> Washer chk
B11 <-> C6 <-> Rear Light chk
B15 <-> A7 <-> ABS chk
B16 <-> B5 <-> LH Turn chk
B17 <-> B1 <-> RH Turn chk
B18<-> Coolant level warning switch wiring does not exist on 97 diagram / cluster chk
C1 <-> D2 <-> Water Temp chk
C2 <-> D3 <-> TC chk
C3 <-> D4 <-> RL chk
C4 <-> D5 <-> RV chk
C5 <-> D8 <-> RE chk
C6 <-> leave wire to where it is .. not connected on the 97 cluster chk
C7 <-> C15 <-> Fuel / BU1-3 Diagram above is wrong..instead of C11 .. C7 is the correct pin.. after having verified actual 92 harness. chk
C8 <-> D22 <-> Fuel / BU1-10 chk
C9 <-> D9 <-> Tach / Ik1-8 chk
C10 <-> D10 <-> Tacho Ground Under Ashtray chk
C11 <-> D11 <-> 10amp DOME fuse chk
C12 <-> D12 <-> Park - Neutral Switch chk
C13 <-> D13 <-> Speed chk
C14 <-> C2 <-> Speed chk
C15 <-> D14 <-> Speed Sensor Pin 2 / Tacho / Ground chk
C16 <-> D16 <-> Clock / SET chk
C17 <-> D17 <-> Clock / HOUR chk
C18 <-> D18 <-> Clock / MINUTE chk
C19 <-> B10 <-> Trip / AB chk
C20 <-> B11 <-> Trip / RESET chk
C21 <-> A3 <-> Water Temp / IK1-9 chk
C22 <-> A2 <-> Water Temp / IK2-24 chk
C23 <-> D23 <-> Left Kick Panel Ground chk
NOTE : There are other pins / wires from the 1997 plugs / pigtails that need to be wired / connected
1) Pin D1
3) Pin D19 should be wired to Pin 5 of the TEMP/ODO switch which is empty right now .. those pins are for the TEMP display.
4) Pin D21
Reverse the plugs to verify what is on the 97 cluster and what is empty
97 <-> 92
A1 <-> B1
A2 <-> C22
A3 <-> C21
A4 <-> B3
A5 <-> B5
A6 <-> Empty
A7 <-> B15
A8 <-> B8
A9 <-> A17
A10 <-> A4
B1 <-> B17
B2 <-> Not used since cluster is for an SC300 and not SC400
B3 <-> B7
B4 <-> B6
B5 <-> B16
B6 <-> A1
B7 <-> A2
B8 <-> A3
B9 <-> A5
B10 <-> C19
B11 <-> C20
B12 <-> A16
B13 <-> B4
C1 <-> Empty
C2 <-> C14
C3 <-> A20
C4 <-> A18
C5 <-> B9
C6 <-> B11
C7 <-> Empty
C8 <-> A13
C9 <-> A7
C10 <-> A11
C11 <-> A10
C12 <-> A15
C13 <-> A14
C14 <-> A19
C15 <-> C7
C16 <-> A8
D1 <-> ??? Not connected cause the 92 internal wiring is non existent
D2 <-> C1
D3 <-> C2
D4 <-> C3
D5 <-> C4
D6 <-> C13 of 97 cluster & A14 of 92 cluster
D7 <-> Empty
D8 <-> C5
D9 <-> C9
D10 <-> C10
D11 <-> C11
D12 <-> C12
D13 <-> C13
D14 <-> C15
D15 <-> A12
D16 <-> C16
D17 <-> C17
D18 <-> C18
D19 <-> ??? Not connected cause the 92 Outside Temp internal wiring is non existent
D20 <-> Empty
D21 <-> ??? Not connected cause the 92 AC Control internal wiring for AMOUT is non existent
D22 <-> C8
D23 <-> C23
92 <-> 97 <-> Notes
A6 <-> Empty
A9 <-> Empty
B2 <-> Empty
1) Pin D1
4) Pin D21
97 <-> 92
A1 <-> B1
A2 <-> C22
A3 <-> C21
A4 <-> B3
A5 <-> B5
A6 <-> Empty
A7 <-> B15
A8 <-> B8
A9 <-> A17
A10 <-> A4
B1 <-> B17
B3 <-> B7
B4 <-> B6
B5 <-> B16
B6 <-> A1
B7 <-> A2
B8 <-> A3
B9 <-> A5
B10 <-> C19
B11 <-> C20
B12 <-> A16
B13 <-> B4
C1 <-> Empty
C2 <-> C14
C3 <-> A20
C4 <-> A18
C5 <-> B9
C6 <-> B11
C7 <-> Empty
C8 <-> A13
C9 <-> A7
C10 <-> A11
C11 <-> A10
C12 <-> A15
C13 <-> A14
C14 <-> A19
C15 <-> C7
C16 <-> A8
D2 <-> C1
D3 <-> C2
D4 <-> C3
D5 <-> C4
D7 <-> Empty
D8 <-> C5
D9 <-> C9
D10 <-> C10
D11 <-> C11
D12 <-> C12
D13 <-> C13
D14 <-> C15
D15 <-> A12
D16 <-> C16
D17 <-> C17
D18 <-> C18
D20 <-> Empty
D22 <-> C8
D23 <-> C23
#2718
Super Moderator
I did cut the cluster wiring , 12" from the pigtails
Today .. took out the dashboard of the 1992 SC300 so I can take out the dash harness and start the grafting
1992 SC300 dash harness has some minor differences from that of the 1994 SC400 dash harness so I will use mine from the 1992 SC300 to graft the 1997 pigtails.
#2719
Super Moderator
This is where I am grafting the 97 pigtails. In that area inside the dashboard, there is enough room at the back to hold the bulge caused by the grafting. Remember, I am not taking out the 1992 plugs. I want to be able to use either of the two clusters..... pre 97 or 97 gauge cluster. It is a lot easier to cut and remove the pre 97 plugs and just replace. But the beauty of just grafting the 97 plugs is you can use either of the two.
Plug A of the 1997 gauge cluster grafted
Plug A & B of the 1997 gauge cluster done
Plug A , B & C of the 1997 gauge cluster grafted
All 4 1997 gauge cluster pigtails grafted
The sphagetti junction... need to properly wrap this thing. It would have been cleaner if 1992 plugs were totally taken out but I still want to have the capability of using a 1992 gauge cluster so I kept them. Just need to properly wrap that thing,.
The 97+ trip switch plus the plug
The 92 trip switch do not have a wire on slot 5 so it has to be added and connected to D19
Picture on top is from the 97 and picture at the bottom is from 92 .. slot 5 is empty as stated. That slot is is for the TEMP Display
#2721
Gerrb,
I wish I had this information like three years ago. I think you are the only one that has successfully completed this. You again, have surpassed as being the "LEXUS SC GOD".....
#2722
Looking forward to this write-up Gerry.....Does the cluster funciton 100% i.e do you get the outside temp gauge..etc.
My car is living proof that it is possible to get a up and running Aristo 2JZGTE swap following his guide.....
#2723
Super Moderator
Thanks guys... I have a lot of people PMed me saying they got their 2jzgte swap wiring harness done using that guide you used Ryan.. Some had a couple of problems here and there but after explaining things to them.. got things working.
I have verified every pins / wires on the Gauge Cluster Conversion table on post #2717 . Except for one or two pins... every wire from the 97 has been matched on the 92 so I don't see any reason why a 97 would not work on a 92.
Honestly , I have yet to do the actual cutting and grafting of wires and testing on my 92 but as mentioned , the table above clearly shows me everything will work due to the matchup.
I maybe wrong but after all the diagram analysis... I have no reason to doubt it will work . BTW, Ryan , for the temp , not sure. I guess we will find out..
Now I need to remove my Red Mamba Two (1992 SC300) dashboard to take out the cluster harness and graft the 97 pig tails. What I currently have whose picture I took was from a 1994 SC400. Surely very similar but I would like to verify .
#2725
Super Moderator
Well guys... check Phoenix AZ and San Rafael CA.. there are two 1997 SC300 5 speed for $6400 .. both from dealerships. I hope forum members get to own them. They seem to be very clean cars.
Also if anyone here in GA , wants a black 1996 SC300 auto tranny shell let me know cause a friend told me he is selling his shell for $1000...no drivetrain and interior is not in great shape. He is scrapping his SC project and instead was installing his 2jzgte swap into a 240sx.
#2727
i'm getting a hugeeeee itch to mod the SC... and throw in a stock 1jz..
i def can't go 2jz due to the costs involved, and what i'd like to do it.
either way, i'll be running it stock for a while. im swaying towards the 1j due to the costs of being able to do it so much cheaper....
#2728
Super Moderator
Like Rey just told me last night, he has a friend who wanted to change his 400rwhp 1jz / R154 setup into V160 / 2jzgte 800rwhp setup. I know hind sight is 20/20 . We all change our mind , always...doing it right the first time saves tons of money though.
#2730
What ever JZ swap you choose should depend on your final goal for the car. What will its use be so you get to decide your power goal and ultimately the setup you need to work on. I know 1JZ is cheaper but at the end of the day, you will be throwing money away if you buy something now just to change things down the line, you might as well wait and save for the right setup .
i'm maybe at 110-120 miles, at a half tank.
