2jzGTE SCs - The Siblings of my Supra MKIV Toys
#3062
I have these Brand New 3 piece Weld 15x10 for Supra Fitment 7.5 BS which were meant for the 1997 SC300 5 speed which I am now selling as bare shell. I believe 3 SCs for me are enough. I was intending to install MT ET Streets 325/50R15 . I was reserving them for that car since my other 3 SCs all have drag radial sets for them already. It takes a month to get this from Order since they have to custom make them. They are not stocked items. Costs $531 each . Will let them go for $450 each if someone is interested otherwise again, they will end up in one of my cars.
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150701_104940_zpsn08viobk.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150701_104955_zpskld54f4g.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150701_105010_zpstzmmxpoz.jpg)
#3064
After tracking my FIPG shipment , it should arrive today and should be able to fully close this engine today and bolt all accessories and get this bad boy ready to rock and roll
I have done a lot of internet searching last night and am positive that the +1mm size intake and exhaust valves I have on the head of this engine are Ferrea Competition +1mm . Knowing also whom I was told built this engine , that well known motorsports company prefers Ferrea stuff in their built heads.
Valves found on the head of this engine :
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150628_204503_zpscg5rh8rv.jpg)
Ferrea Compettion Valves in at least four different 2jzgte heads I found on the net :
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/ferreahead_zps5dvdurgd.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/ferreahead1_zpsjjdtysus.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/ferreahead2_zpsr1ulljkf.jpg)
#3065
funds are there, i will just negotiate with the seller and see what i can come up with. the 1jz router is a muchhhh cheaper option, i could go that route, if i found a good deal on it. its a very old engine, probably with a good amount of miles on it, and since i wont be opening it up, it's only worth not too much money, to me at least... now the R154 tax... let's not get into that. can't believe a trans of that nature is that expensive when i got my CD0009 for 200 bucks. lol
#3066
^^^ And how much are you gonna spend to get everything for that CD009 totally installed and running in your SC ? The work you need to do ? At times we don't consider and put $$$ amount on the time and work / effort we put into something.Let's say you are getting a 1JZ with auto.. how much ? $1200-1400 shipped ? ... a Soarer 1JZ with R154 is what ? $3200 shipped ? So your Soarer R154 is $2000 more or less. You know you are spending way more than that on a CD009 install. An R154 would be drop in if you get the right R154. CD009 ... quite a work. And your power goals are just within what the stock Soarer 1JZ / R154 can do.
Not because you got a CD009 for $200, it will be a walk in the park and that is all you need to spend . BTW , what year / model of car did your CD009 come from ?
Remember .... you got to pay to play. If you want to play with these toys and be doing it like a broke *** kid, you might as well not play with them. They won't last long if you don't do it right. I have nothing against CD009. They have been proven to hold power. People are using them as alternatives to the almighty V160 getrag . I am just taking your argument on spending less with a CD009 compared to the Soarer R154 from factory which I don't believe it is.
#3068
Finally , this +1000rwhp capable bad boy is ready to rock and roll. It will be fitted with a 1100rwhp capable Precision PT-6870 Gen 2 Turbo that spools like crazy for the power it makes. No more laggy 1000hp turbos. I have this turbo in one of my 6speed MKIV and it is crazy . I am thinking, this 3rd SC should be my last so am seriously considering converting this Old Man's Tan SC into a 6 speed car since I have no manual SC but have 3 manual MKIV and 1 auto MKIV. I have two brand new V160 Getrag Transmission and two brand new 6speed Differential I bought from the dealership when I was given the tip that they were being discontinued. I can use one set on this car... move all the 97 sc300 5speed pedals on this car.
3 MKIVs and 3 SCs I believe are enough ... I am starting to have my wife on my tail now
with regards my toys. She said , she sees no end on my projects , lmaol. I have yet to sell my fourth running MKIV and the MKIV shell and the 1997 SC300 5speed shell so I can appease her a bit, lol. It is kinda hard to let go at times when you get attached to something.
I still have one last engine to build though , whose rotating assembly is currently in the machine shop for balancing and block be lined honed for the billet mains. After that , enough building ... time to enjoy them more and more. All I will do is make my cars drink corn syrup , rather , burn E85 ....
Goal for this engine I just finished is make 1000rwhp reliably . Engines Specs are the following :
Built 3.0 2JZGTE
- CP Pistons with upgraded wrist pins
- Crower Billet I-Beam Rods with upgraded 90827 Rod Bolts
- ACL Bearings
- ARP Head Studs
- ARP Main Studs
- Titan MotorSports Dampener
- Titan MotorSports Oil Pump
- Titan MotorSports Timing Belt Billet Tensioner
- Toyota Water Pump
- Toyota Head Gasket
- Gates Timing Belt
Built / Ported Head
- Crower 264 Camshafts
- Crower Springs
- Ferrea Competition +1mm Intake Valves
- Ferrea Competition +1mm Exhaust Valves
- Ferrea Valve Seals
- Ferrea Valve Locks
Others:
- 2433cc Siemens Deka High Impedance Injectors
- 1" ID fuel Rail (-10an on each end)
- Veilside Knock-Off Intake Manifold
- 100mm Throttle Body
- Boost Logic Exhaust Manifold
- Precision PT-6870 Gen 2 CEA BB Turbo
- 44mm Tial Wastegate (thinking of getting the manifold modified and use two 44 mm Tial Wastegate)
- Will be managed by a ProEFI ECU
- Will be fueled by 3 Denso TT pumps on a Fuel LOG through E85 friendly PTFE -10 lines.
[![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_163946_zpsphchbfnb.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164534_zpschlcu0rf.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164607_zpsuzlawo9p.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164631_zpsfbguo8lx.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164646_zpscl5nsqy8.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164657_zpstdj3rp0j.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164733_zpsag0agu4s.jpg)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Built 3.0 2JZGTE
- ACL Bearings
- ARP Head Studs
- ARP Main Studs
- Toyota Water Pump
- Gates Timing Belt
Built / Ported Head
- Crower Springs
Others:
![](http://i1010.photobucket.com/albums/af227/gerrb/3rdSC4002jzgteProject/20150702_164803_zpsbdqby5ej.jpg)
#3069
Someone PMed me and asked me what is the reason why I was tearing apart the rare 1997 SC300 5speed and using its parts into my SCs instead of building it.
You see , all my other 3 SCs are all 1992. In GA, any 25 year or older cars do not need inspections or emission tests. So in the next 17 months my SCs will be exempted. I don't need any work arounds to keep them registered and enjoy them. Where as the 1997 , that is another 7 years before it is exempted. My toys will never pass emission / inspections. For me to get them into the RWHP level they are in, exhausts components have to be modified... huge downpipe / midpipe and no cat converters = fail .
So the 1997 SC300 5 speed bare shell is for sale. I don't feel like building another SC after this old man's tan project. it is only good for anyone with a 5 speed that was totaled or wrecked like one with bad quarter panels or has a salvage or rebuilt title . I am using the interior , body kit, lights and pedals , wiring , everything except bare rolling shell in my current project. It will be a 1997 in a 1992 body.
The 1997 has 115k on the cluster and has a clean title. You will have the rare 1997 SC300 5 speed ..though just a bare rolling shell
. You will be paying a 1997 SC300 5speed tax , lmaol. I can trade also for anything that maybe useful to me for my toys.
#3070
You see , all my other 3 SCs are all 1992. In GA, any 25 year or older cars do not need inspections or emission tests. So in the next 17 months my SCs will be exempted. I don't need any work arounds to keep them registered and enjoy them. Where as the 1997 , that is another 7 years before it is exempted. My toys will never pass emission / inspections. For me to get them into the RWHP level they are in, exhausts components have to be modified. No cat converter = fail . .
#3074
Decided that I will give some love on the exterior of this car aside from it getting a really good black interior. A friend had an accident on his 97 car , rear ending somebody. He decided just to part out his car. So yesterday , I scooped the side skirts and rear bumper and decided they will go into this car. The door moldings my friend lilscteve wants them otherwise, I don't mind scooping them too for this car. I am keeping the front 95-96 bumper and am in search for a set of 95-96 tail lights so I have one of my SCs with that generation look though with side skirts and upgraded rear bumper.
![Name: 20150704_111102_zpszifuxl6v.jpg
Size: 143.4 KB](https://www.clublexus.com/forums/attachments/build-threads/452591d1501528246-2jzgte-scs-the-siblings-of-my-supra-mkiv-toys-20150704_111102_zpszifuxl6v.jpg)
![Name: 20150704_111125_zpskzd6r8st.jpg
Size: 157.0 KB](https://www.clublexus.com/forums/attachments/build-threads/452592d1501528246-2jzgte-scs-the-siblings-of-my-supra-mkiv-toys-20150704_111125_zpskzd6r8st.jpg)
![Name: 20150704_111155_zpslog8bmd5.jpg
Size: 170.8 KB](https://www.clublexus.com/forums/attachments/build-threads/452593d1501528246-2jzgte-scs-the-siblings-of-my-supra-mkiv-toys-20150704_111155_zpslog8bmd5.jpg)
![Name: 20150704_111220_zpsw6c5ve85.jpg
Size: 143.1 KB](https://www.clublexus.com/forums/attachments/build-threads/452594d1501528246-2jzgte-scs-the-siblings-of-my-supra-mkiv-toys-20150704_111220_zpsw6c5ve85.jpg)
![Name: 20150704_111235_zpscbix4vrn.jpg
Size: 155.4 KB](https://www.clublexus.com/forums/attachments/build-threads/452595d1501528246-2jzgte-scs-the-siblings-of-my-supra-mkiv-toys-20150704_111235_zpscbix4vrn.jpg)
#3075
1 Post
Mang Gerrb, That 2jzgte motor is always looking awesome like the rest of your 2jzgte build, lol... Im not sure if you received my text, i asked if you can share where you get your gte block honed. Text me or pm me the shop name if thats cool with you.. TIA!
