Did you buy a patch harness for the 128 to connect to the SC?
Shane
Shane,
I made my own gte harness and patch harness for the proefi 128 since the patch harness is sold for $500. You should be able to do it since you can tinker with wires. The pin configurations is available on the ProEFI website.
BTW, I didn't get any PM from you. Try to check and resend please.
back from my summer vacation so got to finish what I need to get done and unload / sell all the stuff I really do not need after all the thinking I have been doing this past weeks during my Safari Trip.
Current engine I am working on is all prepared for a 1000rwhp setup. Before I bolt on the Precision PT-6870 , I decided to wrap the exhaust manifold with DEI wrap to minimize the heat on the bay.
You need to let me have one of those ATF trannies. I can put it to good use.
Shane
Sold the extra through SF to a guy in West Coast. I still have one , if I don't end using it , will let you know. I wanted to see though if it will hold 1000rwhp so was thinking to mate it with this engine am currently working on.
Originally Posted by chnk
You have a 6870? ****ttttttttttttttt
I'm about to wrap my manifold in titanium wrap too
yeap... got three. One for sale , another on my 3.4 stroker MKIV and the other for this engine ! Rated 1100rwhp and yet spools almost like a 67mm. ... indeed a true 1000rwhp turbo which is perfect for this setup.
hey .. i will try to take out the drivetrain this weekend and you can pick up the shell on Saturday afternoon or Sunday so I can clean up a bit my place .
If you do, please give me a shot at it first. I need one.
Shane
Will do Shane !
Chris - here is the PT-6870 . Got the Divided 1.0 a/r turbine housing since am planning to use a SP Quick Spool Valve to make it even more responsive at 1000rwhp. Turbo actually looks small or as big as the PT-6765 I have on the other SC.
so i plan on running a BW s366 along with a cast iron manifold.
thoughts?
A lot of things you need to consider when you choose your turbo setup... purpose of car , hp goal , mods on your engine , etc.
Assuming you want a good street setup , choose the smallest turbo that would support your power goal / engine mods so you have a very responsive setup on the streets meaning it won't be laggy. It will be different though if it was a drag car where you need power at the top end.
hey , can you get Chris SC shell be picked up friday afternoon ? I will be in that area that day.
Instead of installing the 12 injectors Hypertune Intake Manifold with direct port nitrous on this car, decided to keep the Greddy Intake since I don't think that intake will sell anyway. I started doing proto type engine covers that I will get done in aluminum plates that I can probably get chromed or polished or blacked out whichever is better... I like a cover just like that chromed ABS cover on the top left.
