2jzGTE SCs - The Siblings of my Supra MKIV Toys
#662
Gerry ,
I think the easiest way to install these and set it up properly will be to remove the tank and and take your time with it and if you are gonna add a third pump you should pull a tank out!
Nice progress BTW
Nice progress BTW
#663
OR install it outside , be fed by the 2 pumps since I only have 2 TT denso now and the big external pump .. all staged based on boost . I probably might as well just use what I already have rather than buying another TT Denso pump.
Hhhmm..
I know someone will jump in and frown about the idea of me
having 2 TT denso pump and a 1500hp external pump ..
OVERKILL !!!!!! . But , that is what I already have . That big brand new pump had been sitting in my garage for 4 years now . I might as well use it. And it will be turned on only above 700rwhp. At that point pump noise will be drowned by exhaust noise
Hhhmm..
![Peep](https://www.clublexus.com/forums/images/smilies/peep.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/2012-05-26_16-52-23_290.jpg)
#667
![Sai](https://www.clublexus.com/forums/images/smilies/SaiyanSmilie_anim.gif)
Well , at least I know got one on my side .
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
#668
If you want to install that fuel log or 3 pumps inside the tank , as Omar mentioned , taking out the tank is the best thing you can do to make your life easier.
Fuel log on the top hat , well above the slosh tank .. so that is a nice place to install it and feed it with the three pumps.. BUT am seriously considering mine to be outside the tank since my third pump is an external one.
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/2012-05-26_21-50-32_273.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/2012-05-26_21-51-07_433.jpg)
#670
#671
![Dance](https://www.clublexus.com/forums/images/smilies/dance.gif)
Hey , it is all good. I try to learn from every possible word I hear or read .I can't expect all good words. I try to handle all criticism well and filter them in a way that makes me a better person either in my knowledge or character.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
BACK to the fuel tank .. am taking it out this morning . It is easy , got a 14mm bolt on each corner and 3 banjo bolts at the bottom . (feed,return,canister/vent)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/2012-05-28_10-33-34_585.jpg)
#673
LOL this reminds me of that poor guy who posted a youtube vid of him removing his fuel tank to replace his stock fuel pump. He figured out after several hours of unnecessary labor that the pump access is behind the seat
Anywho, great progress sir. Clearly this is no budget build.
#674
#675
feed from the internal denso pumps will go into these -6an bulkhead which will be installed on the fuel sender hat which can be capped while not in use. Will install three of them but will only need two so I have room for expansion. With these, I will now have to install -6 an / -10o-ring fittings on the fuel log to accept the feed instead of the -10an/barb that are installed now.
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/2012-05-27_11-34-59_796.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/2012-05-27_11-36-10_795.jpg)
