2jzGTE SCs - The Siblings of my Supra MKIV Toys
#858
1 Post
Hello Sir, love the black interior on that Red Dragon..ill pick the No.1 ^^ option cuz u already have monster fuel system to accomodate the 272 6speed Power plant. then u can give me one of your stock 2jzgte
#859
I want an auto cause I already have a 6 speed on my stroker supra. But if I use the built engine on the Boost Logic Auto Transmission , I don't know how much that tranny can hold and I hate to waste a tranny. They say they have seen over 800+rwhp. I believe my built engine with 272 cams , 6 x 2433cc Siemens Deka injectors, and billet precision 6765 will be a perfect match ... since that turbo is rated 900hp . But I will need another ECU since what I currently have is a Haltech Platinum Series 2000 and they are only for standard / manual transmission. Damn .. that is another $2k if ever.
#860
I don't know buddy ... I can't make up my mind ... need to think and think
I have to decide wether I still want to work on another project or not.. IF not then , the built engine is going into the Red Dragon. It is now a question of 6 speed or Boost Logic Auto . IF I go auto then I need another ECU since what I have is a Haltech PS2000 . Where as if I go 6 speed , all i need are pedals/master clutch /slave/tunnel and some small items.
#861
1 Post
your goal on the Red Dragon is around 700ish HP.. if what they say is true on that boost logic trans, then your correct it will be a perfect match. i would love to see that built engine 272 on that Red Dragon tho.
#862
1 Post
hey .. long time no hear .. we can talk about the stock 6 speed 2jzgte engine for your SC . Is your car still at home or have you moved it ?
#863
Its injectors are perfect for E85, they are the 2433cc Siemens Deka . Even at those size of injectors , they idle so good at around 900rpm with the 272 cams.
I just have to use my 4" downpipe, midpipe and exhaust with the HKS super dragger instead of the TRD exhaust. TRD is only 3.5" ...
I am decided to use the built engine .. what I am debating about now is 6 speed or Boost Logic. I might as well go all out on this SC to make it a true sleeper... anything that will make it fast , making it pretty is secondary. Sometimes making a car look pretty on the outside gets into the way of speed. Like 19" wheels are nice but no way to put down the power without rubber on your wheels.. I will prefer a stock looking SC as long as it can support my ego on the streets when the needs arises.
#864
I will have to cut a 5" hole in front of the wheel well floor to accomodate my air dam/air scoop. I want my velocity stack right infront of the opening near the right fog light so it can scoop all the cold air the turbo needs. When it is raining and I have to use the car which I doubt. I can just remove the lower portion of the air dam/scoop and connect a 5" filter inside the engine bay.
#868
Since I am decided to use the built 2jzgte , now I won't use the 3.25" TRD exhaust with the 3" RMM down/mid pipe. It will be for sale on the ads section. I will instead use my 4" downpipe , midpipe , and HKS super dragger II exhaust
TRD Exhaust & RMM down/mid pipe
HKS Super Dragger II with 4" downpipe / midpipe ... .4" all the way down to the exhaust
Decided to paint them using 2000 degrees F paint...
