2jzGTE SCs - The Siblings of my Supra MKIV Toys
#917
Those who got answers are encouraged to chime in.
#920
installed a 200amp circuit breaker .. used gauge 0 cables and there will be a distribution box on the engine bay
and there will be two ground .. one connected to the bottom of the tank and the other am still looking for a good spot.
#921
Weldon 14000 controller for my Weldon 2345a racing pump is now mounted ...
The 4 x 40amp relays that control/provides power to each TT denso pumps and the Weldon 2345a pump mounted on the cross bar infront of the speakers..will probably use two bolts screws to hold it instead of 1
#922
To have a more reliable fuel system, decided to use the Weldon 2345a pump , weldon filters with my 3 x TT Denso pumps instead of the OBX 1500hp pump and summit racing filters as my backup / kill mode pump . No tuner should ever complain that he doesn't have enough fuel now... not even E85 which uses more than 30% more.
#923
Sorry to say it but your fuel system is utterly ridiculous for a street car triple Denso's are more then sufficient to do the job.
I run 3 Denso's with 2150cc injectors and at 855hp on E-85 and I'm at a 42% duty cycle in full boost 30+ psi at 7000+rpm's
#924
Just like you had 3 TT Denso ...everyone is free to use the same or do something else. Just because you have it or are probably more knowledgeable than others , it doesn't mean that everyone should have them . Can't anyone do something else he wants in his build thread that is not like yours ? I installed another external pump for some reasons you may not agree... as a backup and some other reasons. On my end there are reasons why I did it. It might be ridiculuous to you but not to me. I will do whatever will make me happy , after all it is my money and my car. I am building a car not for others to be happy or agree with. I am simply sharing what I am doing in my car.
It is just funny that when I first brought out the idea of having 3 TT denso pump plus the big pump as backup, you were quick to judge people on this site or quick to say "I am sorry it is only on clublexus that there is such a thing as overkill on fuel system." .. Now I still have exactly the same setup . It is just that I used the Weldon instead of the OBX pump as a backup and you say it is ridiculuous. I figure now that you didn't read well then what my fuel setup was, before you even typed the comment I mentioned above. There was no change to the setup , just the brand of pump. So I can't figure now why all of a sudden it became ridiculuous. Just a 180 degree reversal on your end.
But I will always respect yousr or anyone's opinion/comment cause each one is entitled to. But that won't stop me from doing what will make me happy regardless . I am building this car for my own and only my own satisfaction and gratification and not for anyone else . I will continue to share what I do to my car not unless the forum says otherwise . As far as I am concerned that is what the build threads are all about .. sharing what you did to your car. This thread is not meant to teach anyone. It is not a DIY thread. As I always said, I am just a damn newbie who likes to learn. I don't brag about knowing something I don't know. What I am simply doing is sharing what I am doing to my car and encouraging people to work on their cars. I am not telling people to do what I am doing to my car.
Just saying
The truth hurts!!!!!!
#926
Just to answer questions why do I really wanted a backup big pump when I have 3 denso TT pumps... let me explain so those who read the thread will know my rationale. I am not installing one just for the heck of having one ...
In a perfect world , having 3 x TT Denso pumps will do all the work for a 1000rwhp engine. Since you are not on high boost always , you can stage pump 2 and pump 3 based on boost to provide you all the fuel needed and noise can be controlled. I know having a backup big pump sounds ridiculuous as one puts it but not to me since there can be scenarios that the backup pump will come handy.
a) What if your main pump , fails ... you will need to be working on your car on the road or wherever you are just to replace that pump and bring you home cause pump 2 and 3 only work on the higher boosts only.
-> with my backup pump, I can just flip that over ride switch and I can go back on the road on my way home
b) lets say you are on high boost , one of the pump konks out .. what happens to your engine ? ... goes lean and we all know the catasthropic effect of that to the engine.
-> with my backup pump, as soon as the pressure drops on any of the 3 individual fuel lines going to the fuel log from the TT pumps , the backup pump can be fired to avoid any lean situation.
c) I am setting my fuel system so it can be as flexible as it can be. With such a setup I can also have the option of using 1x TT denso pump for cruising only up to 400rwhp since it producess less noise and on high boost fire the big pump instead of the 2 other TT pumps. The plumbing and pump setups makes me more flexible ...
d) I have this big pump laying around for at least 3 years now so I might as well use it.
I know no one probably has done such a setup thats why someone calls it ridiculuous... but since I have the opportunity to have one , why not ..
I hope that explains why such a fuel setup ....
#927
no. i was having the same problem as you. i got some sc300 lines and they would not work on my sc400 firewall. mark somehow made 300 lines work. iirc if you get the same model year as the car then they should interchange. but again my lines didn't work for me either.
#928
Gerry ,
I understand your point behind this but you just need a better EMS, and you won't have to worry about pump not coming ON at certain PSI.
We all know the answer ! P.r.o.e.f.i
gl
gl
#929
thanks for the info , at least that confirms my suspicion. Now I am tempted to use the dremel on the firewall or the line itself to make it work .. I don't know what to do now.... what you think ? Have you done anything on yours ? I hate to look for another AC line ..
#930
So I am trying to choose a route in which I can make use of what I already have and at the same time achieve my long term power goals for this car.
