Build Threads Details on Club Lexus SC owner vehicles
2jzGTE SCs - The Siblings of my Supra MKIV Toys
Old 07-14-12, 10:40 AM
  #946
gerrb
Super Moderator
gerrb's Avatar
Since am using an aftermarket oil cooler with the sandwhich plate , I decided to take out the wrap around water pipe that connects to the stock oil cooler where the oil filter is bolted on.
Am installing a water temp sensor on this hole to cover it .... but I don't know if that is a good idea for a water temp sensor on that part of the block for now since I am not sure if it is cooled coolant that came from the radiator that is on that line...
and took out this wrap around water pipe
Old 07-14-12, 10:41 AM
  #947
gerrb
Super Moderator
gerrb's Avatar
Am using a GE water pipe instead
  #948
gerrb
Super Moderator
gerrb's Avatar
comparison between a gte water pipe and ge water pipe
Old 07-14-12, 10:42 AM
  #949
gerrb
Super Moderator
gerrb's Avatar
GE water pipe installed
Old 07-14-12, 10:47 AM
  #950
gerrb
Super Moderator
gerrb's Avatar
Reading a thread on SF about oil pressure on the lexus union bolt being measured lower , decided to put the oil pressure sensor on the line going to the filter instead of the return line which is the union bolt hole.
Old 07-14-12, 11:15 AM
  #951
Vwpride12
Vwpride12's Avatar
We usually mount our oil pressure sending units on the body of the car and run a braded line to them. We have seen them break when mounted to the block probably from vibration. Just a thought.
Old 07-15-12, 07:26 AM
  #952
gerrb
Super Moderator
gerrb's Avatar
Thanks buddy for the suggestion. Will look into it.
Old 07-16-12, 04:31 PM
  #953
babillarac
babillarac's Avatar
Originally Posted by gerrb
Hi Omar , yeap no updates for now I know . I will be lagging for a while on this project... am on a well deserved vacation, man ... ... . So far had been going around some states... In and out my place in North GA . Too tired to work on anything when am home. Hopefully soon I will be able to do something when all this travelling is over. If I don't go to Europe/Olympics I will see you in Tampa by end of his month.
sweet hit me up,if you come down
Old 07-16-12, 07:35 PM
  #954
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
It's coming along quite nicely!
Old 07-17-12, 12:29 PM
  #955
gerrb
Super Moderator
gerrb's Avatar
Will surely do man ..
Old 07-17-12, 12:33 PM
  #956
gerrb
Super Moderator
gerrb's Avatar
Thanks Mark !
got a quick question for you.. I know you have a 1992 SC400 .. what AC lines from the firewall did you use ? .. one from an SC300 ? the ports that bolts on to the firewall are not of exactly same size with that of the SC400.. how did you get about with those ports on the firewall ? OR did you use a newer model SC400 AC lines ?
That is the thing am trying to figure out before I drop that engine in the car while I got an empty engine bay ..
Old 07-17-12, 03:00 PM
  #957
megamax
megamax's Avatar
^^answer him mark(waiting to take notes)
Old 07-19-12, 03:37 PM
  #958
cartmill
cartmill's Avatar
you can reuse the sc400 line coming out of the firewall, but it has to be SC300 from that connection point all the way over to the 2jz AC compressor.
IIRC they are two big long awkward lines that run all the way from the passenger side frame area over to the compressor.
i used my sc400 lines and just cut the ends off and welded on the sc300 ends so they would bolt onto the sc300 AC compressor (the angles/fittings/etc. are all different over by the compressor between sc300 and sc400)
Old 07-19-12, 04:25 PM
  #959
gerrb
Super Moderator
gerrb's Avatar
Thank you sir........thats what I will do. Once I am done with this summer travelling, will get more things done. hard to post stuff with this keyboards of smartphones
Old 07-25-12, 03:52 PM
  #960
PoGikoSc4
PoGikoSc4's Avatar
Yo Gerry..your car ready for Tuning yet?
Quick Reply: 2jzGTE SCs - The Siblings of my Supra MKIV Toys
