2jzGTE SCs - The Siblings of my Supra MKIV Toys
#1036
Super Moderator
Learned something new tonight while I was installing the transmission mount and cross member . Damn SC300/400 or even Supra auto trans cross member wouldnt work with the BL twin turbo auto tranny on a Lexus SC. The threaded mounting holes under the car do not match with the holes on the cross member. I had to use one from the 6 speed transmission cross member. I am glad I had one.Now that makes me wonder why .... Is it because the SC300/SC400 has a longer wheel base ? But isn't the SC300/SC400 A340e/A341e auto tranny same in length as that of the Supra A340e/A341e? IF yes so how come the cross member from the Lexus SC wouldnt work ? hhhmmm... .. maybe the gurus can enlighten us a bit.
Upper picture is from a Supra 6 speed tranny and lower is from a Supra TT auto tranny which is same for Lexus SC auto tranny
6 speed tranny cross member was used with the BL auto tranny
#1040
Super Moderator
^^^^ Sorry , my bad... you are right ... posted a picture taken when I was trying the driveshaft before I took down the old diff .... pictures of TT auto diff with the cooling fins you are saying now posted above
#1041
Super Moderator
See you at 3:00pm today .. should be in my Roswell place by that time.. you better bring a truck .. .. if you want to haul stuff I don't need. The only things you can't have are my 6 speed 2jzgte engines and trannies. I am installing one of those on the other SC400 once the damn 1uzfe konks out.. I even wonder if it will ever goes caput.. .at this point it has 254k miles and is still running strong
#1042
Super Moderator
I guess I need to get my down pipe shorten by an inch or two .. to raise up my 4" mid pipe ...and definitely should button / fasten my -10an & -8an teflon fuel lines under the car now ..
#1047
Super Moderator
Today I also received my TXL gauge 10 wires for my 3 x denso TT pumps and fuel feed tubes which are supposed to be E85 friendly since they will be submersed in E85 inside the tank. I can now finalize my in-tank pumps setup ..
#1049
Super Moderator
Nah .. you don't have to stay away from the red dragon when you are here , let me know when you are around so we can terrorize the neighborhood. I will cruise around as stock looking and sounding as possible ...
