2jzGTE SCs - The Siblings of my Supra MKIV Toys
#1247
I know we need to meet ....lol.. I started it yesterday .. fired up right away with E85.... I tried it on my driveway...forward and reverse .. that's about it . I still don't have the actual ECU for it. I need to sell a lot of junk I have in my garage so I can free up some funds. I just used the proefi from my supra so I can check if there are oil or fuel leaks... none.... which is good news. I need to change my lower intake runner with the runner that has the hard nitrous lines once I am done working on those lines so it can be tuned with nitrous .
My next problem even if I get a proefi ecu is who will tune it....... nearest one is 500 miles. The current tune I have on my supra proefi wont work since it is for a stroker motor with a 7685 turbo and a bit smaller injectors ID2000... My injectors on this SC are bigger 2433cc siemens deka and turbo is smaller a billet 67. I am currently trying to find my way around the ECU... playing around with it. But I still need a pro to tune it...
#1248
Great , all you need then is extend the dash harness for your digital cluster since it came from a RHD car and you are all set. I hope you are using the original soarer engine harness too. The digital harness is controlled by the ECU thus it relies on the original harness connections on ecu, engine sensors and fusebox. I did take a video of the start up but the exhaust is so loud , you hardly hear the engine / cams' lope since I only have up to the mid-pipe installed for now. But the engine sound is same as the one I showed you before when that engine and exhaust was in one of my supra. I need to get the cat-back portion of the HKS Super Dragger II extended around 8 inches I believe. This exhaust came from one of my supra and the SC has a longer wheelbase than the MKIV.
#1249
My daughter is learning how to drive. She had already been asking me what car will she drive.I don't want to give her my platinum metallic color sc400 cause it may start giving her problems and get her stranded being a high mileage car. I have no plans of buying a new car for her and at the same time I hate to give her one of my big vehicles I don't use being a new driver. So anyone around here want to trade their reliable car with comparable value with a)GMC Sierra with a Fabtech 7.5" lift kit / 35" M/T wheels & tires with 70k miles which I had since brand new OR b) GMC Yukon XL Denali AWD with 20" wheels & 120k miles which I had for 7 years now I believe.
In the background
Close up pics
In the background
Close up pics
#1256
#1259
Mark - this is what I want to do...rear bottom seat delete.. I will keep the rear backrest so it will still look stock looking inside through the windows or windshield.... and want to keep some stealthiness.. The amps.. I guess I can get them into the trunk.
subwoofers enclosures that looks like this but I want it with 4" port on both sides since the DLS subs I have are better with a port... ...this is a picture of an unfinished sub figerglass enclosure.. I wonder who can do this for me and costs involved.
