2jzGTE SCs - The Siblings of my Supra MKIV Toys
#1292
All I have to do when I want to move the fusebox to the trunk is cut the wires near the fusebox and extend them towards the trunk. That will be for some other time.
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130306_094541_zpsd295ca41.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130306_094554_zps06bd3839.jpg)
#1297
I have been slowly gathering parts for my direct port nitrous setup and some items have arrived so I have something to do this weekend.
Got the tap I need plus the 1 in 6 out nitrous distribtion blocks in the mail yesterday.
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_102027_zps44e2e2ac.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_102751_zps9260f849.jpg)
Now I can drill holes on my extra runner which I painted garnet red (3k3) and tap them so I can install the NX piranha nozzles for each runner. Though I have to practice in another older runner so I don't mess things up. All I am doing on this built is through guts and courage .. no previous experience...neither am I a mechanic or pretend to know much. My previous personal sad experiences in getting someone else do the work for me made me tell myself I might as well do things myself. Well of course , both of my Supra were bought ..
.. But on this SC it is a project I decided to embark on myself. All I do is a lot of reading and research and lets see how things will turn out... lmaol. At least I have no one to blame but myself.
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_103046_zpsebf5edf8.jpg)
#1298
Since I am free today, decided to work on the runner instead of waiting for weekend. I worked straight on the runner I will use instead of practicing on the other one since I believed it was easy enough. I did some measurements and markings just to make sure that the nozzles are in the right place. They should not interfere with the Siemens injectors , railings , cam sensors and the vacuum sources on the intake plenum .
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_114933_zps4dd90f3c.jpg)
They would be near the injectors and railing
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_120843_zpsd04e8768.jpg)
#1300
So at present , am tapping the holes .. should be done in an hour or two.
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_123907_zps48080406.jpg)
Being a soft metal, it took less than 30 minutes to tap the six hole. You got to be very careful...the metal is so soft and could easily loose that thread...
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_125150_zps98c5e4a2.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_124242_zpsfe29290f.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130315_140801_zpsd960fe7e.jpg)
#1305
The nitrous stainless steel hard lines will look better on top of a black background and so I decided to paint the lower runner black . Besides my fuel rail is red too so having a black background is a lot better. I have installed all the nozzles , the purge solenoid , nitrous and fuel solenoids with the distribution blocks and fittings.
All I have to do is wait for my stainless steel nitrous hard lines from Nitrous Express which is taking a while to ship so I can fabricate the lines. I still have to source a 37 degree flare tool which is good for stainless steel tubes. I couldn't justify spending over $100 for one which I will probably use only once.
Here is my intake manifold now ...
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_154738_zps6d3d97c6.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_154748_zps2b511053.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_154820_zpse935d21b.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_155006_zps2d7d9a1d.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_154928_zpsdd9cbb14.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_154910_zps13f6898a.jpg)
![](http://i1010.photobucket.com/albums/af227/gerrb/SC4002jzgteProject/20130316_154722_zpsdd94fcf5.jpg)
