2jzGTE SCs - The Siblings of my Supra MKIV Toys
#1427
1 Post
wow those Weldons are crazy loud.. to lessen the vibration/noise,.. will it help if you put like a rubber damper where you mount it? Did you buy the lift? Maybe i can drop off my SC to your place down south and have you finish her. for a fee ofcourse
#1428
What I want to do is when I am almost done and am ready to install a good sound system , I will install sound deadener / dampener all over the trunk so the pump noise is enclosed and hopefully won't hear it much inside the cabin.
The lift was just being given away. The motor shop closed its doors and the owner of the place wanted it out. Well , I can help you out with your car , no fees .. , just get the drinks ready , lol.
#1429
1 Post
[The lift was just being given away. The motor shop closed its doors and the owner of the place wanted it out. Well , I can help you out with your car , no fees .. , just get the drinks ready , lol.[/QUOTE]
I hope youre taking the lift if its givin away.. Maybe after i get back from P.I. we can tackle my SC in one day. Just let me know w/c one you prefer Black/Blue Label or Macallan 18yrs (all 3 sounds good ).
#1431
The altezza or lexstacy headlights on the 6 speed project had to go so I swapped its lights with that of the platinum... headlight needs cleaning . As 1jzpwrd said , "gerrb , those headlights have to go " ! I am not a big fan of the 97+ kit , I am tempted to install an older bumper on this car. Since I am planning to get it painted black , I will call it Black Mamba .. lol . The red dragon won't take long and should be running. I am still waiting for some fittings. I believe I have more on fittings on that car than the cost of the car when I bought it . I have to refer to the gurus / tuner on how exactly should I plumb my fuel supply for the Direct Port Nitrous. I have read that they should have their own fuel supply / regulator . I was just wondering wether I can tap the supply from the Weldon which is a lot of fuel already. But again , having its own regulator , allows the tuner to tune it exactly with the right fuel pressure based on the size of the nitrous jets you have without being affected by anything else. I don't know .. I will let the tuner decide on it.
Hmmmm , I just noticed , the platinum has glass high beams .. need to transfer those on the red dragon .. lol. Can I remove high beam lights without taking out the bumper ?
#1433
yes I still have those 440cc ..
#1437
Am ready to tear this black mamba apart since I can't move on with the red mamba till I have some other parts I need like fittings / bungs. On the other hand , maybe I can get the stroker engine first built . That will enable me to move around the car when the need arises rather than pushing an empty shell.
#1439
I will get a well known supra builder to do the whole long block from the oil pan to the valve covers. I was thinking of Errol from TPS at West Palm . He did the block of someone I know here in GA. And very nice guy I was told . Even when you are far , he supports you good like people I know who bought a PROefi from him. Just very helpful I heard.
I will not experiment on something very expensive. The stroker kit alone (crank,rods & pistons) is almost $8k already, then you have your 1/2 main caps ,head rebuild with ferrea valves / etc and shimless buckets . That is something I can't imagine doing myself. That's why I want the whole thing assembled by the PROs, all I want to do is slap in the accessories. And this might take time. First I will have to gather all the parts then take things to them.
Since I will get the car painted black , maybe taking it apart is a good idea.
#1440
1JZ Single SC400
You know honestly, I have never priced the stroker long block with all the work involved. I knew that it was expensive, but not that expensive. You know you have to pay to play! I say give him a call and see what he can do for you and see if you can get a better price than 8K.
