Kez's 1992 Sc300 1jz Build
#91
^^wth!! where are my pm's
-obvilously it looks like the wiring would/is a problem for you. so you should send it to account 2x. cheaper than dr tweak(by alot). and helpful on the installation/trouble shooting side.
you really should pull your head and check out all your cylinders. those cams look really dirty. i didn't have that yellow snot looking stuff in my runners. just normal carbon.
#95
Well, as of now nothings hooked up, all I did was drop her in, and hooked up a few lines, hopefully tuesday she runs, all I need now is some fluids, and the intercooler and piping and then she should be drivable
#96
hey fellas got off worka lil early today so i had time to get a lil stuff done and make a list of what i need.
well i grabbed the ignitor that came with my swap but when i try to plug the ignitor in only the smallest plug connects and the larger one doesn't. so I'm pretty sure its the wrong on just wanna check with you guys.
OHH YEAH hey 1j GUYS are you using the v6 camry throttle cable or 4 cylinder throttle cable? I've seen a post somewhere about corolla cable too IDK chime in
#97
[IMG]
IMGP3711 by kylephillips1991, on Flickr[/IMG] [IMG]
IMGP3710 by kylephillips1991, on Flickr[/IMG] OHH YEAH hey 1j GUYS are you using the v6 camry throttle cable or 4 cylinder throttle cable? I've seen a post somewhere about corolla cable too IDK chime in
[IMG]
#100
[IMG]
[IMG]
#102
Waitin on my intercooler and piping to come in, everything else is ready to go, only thing left is jumping the resistor behind the cluster, got my temp gauge workin, check engine light workin, starts up with no codes
#104
Okay guys need some help with Alternator stuff. Here is the 2jzGE Alt and its plug http://www.flickr.com/photos/kez1991/7989539000/http://www.flickr.com/photos/kez1991/7989539000/ by http://www.flickr.com/people/kez1991/, on Flickr http://www.flickr.com/photos/kez1991/7989533834/http://www.flickr.com/photos/kez1991/7989533834/ by http://www.flickr.com/people/kez1991/, on Flickr http://www.flickr.com/photos/kez1991/7989527870/http://www.flickr.com/photos/kez1991/7989527870/ by http://www.flickr.com/people/kez1991/, on Flickr
and here is the plug from my soarer harness which runs from the intake side around the rear of the 1jz to right where the ALT is mounted. question is is this the ALT plug and if so which wires matches with which?
this is where it is right where the ALT is mounted
