Build Threads Details on Club Lexus SC owner vehicles
Kez's 1992 Sc300 1jz Build
Old 09-16-12, 05:12 AM
  #106
kez
kez's Avatar
Nvm that plug in my hand in last picture should not be the alt plug. I've found this thread https://www.clublexus.com/forums/per...lick-here.html
Hopefully I can find where the wires are cut before I do this
Old 09-16-12, 06:04 AM
  #107
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Glad you got it figured out. I used the stock wiring in the car and tied the 1jz harness side back out of the way.
Old 09-16-12, 03:01 PM
  #108
Vrank
Vrank's Avatar
That oval plug you have in your hand appears to be the speed sensor plug that goes on the trans.
Old 09-16-12, 05:40 PM
  #109
kez
kez's Avatar
Yeah it is
Old 09-17-12, 07:59 AM
  #110
TweakTech
TweakTech's Avatar
The reason your 12 pin igniter plug is not plugging in is because there is a locking plate stuck in there. Notice on the 4 pin when you look in there, it's all black, and on the 12 pin side, there's a white piece of plastic? Pull that white piece out and your plug will plug right in.
Old 09-17-12, 08:24 AM
  #111
kez
kez's Avatar
Thanks tweak tech but had that all covered already lol
Old 09-17-12, 01:00 PM
  #112
kez
kez's Avatar
Hey guys im back below are photos from inside the engine bay in my 92 sc300 next to the fuse box and the others are on the 5 speed soarer harness. im pretty sure i can just cut and match up the connectors with the thicker gauge wires. just need some insight on this
Old 09-17-12, 01:03 PM
  #113
kez
kez's Avatar
i should just be able to take thematching connector in the last picture from the GE harness and put on my 1jz harness correct?
Old 09-20-12, 09:40 AM
  #114
kez
kez's Avatar
Gross Gross Gross car sat for whole winter and summer. i got off of work early today and started to tackle the rear sump oil pan swap and i see this crap!
Old 09-20-12, 09:47 AM
  #115
xspsi6
xspsi6's Avatar
Looks like either water or coolant got mixed in with the oil.
Old 09-20-12, 10:45 AM
  #116
kez
kez's Avatar
now i have a reason to keep the 2jzge and build a NA-T 300zx.
Old 09-20-12, 01:05 PM
  #117
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thats plum nasty, flush, flush, flush, or rebuild or swap... Hate to see that man...
Old 09-20-12, 02:40 PM
  #118
kez
kez's Avatar
It's not from my 1jay that milky stuff is from the stock 2jzge
Old 03-05-13, 12:06 PM
  #119
kez
kez's Avatar
HOLY CRAP ITS BEEN A Since i posted on my Thread !!!
Ive been gathering parts and since its a decent day here in jersey i can finally get some stuff done
OK 1jz guys i need help with these coolant lines i know the line that is connected to the metal pipe goes to the water pump but I need to know where this smaller line goes on the stock twins.
and also were does the larger coolant line on top of the heater core route to?
http://www.flickr.com/photos/kez1991/8531258045/http://www.flickr.com/photos/kez1991/8531258045/ by http://www.flickr.com/people/kez1991/, on Flickr
Old 03-20-13, 04:21 PM
  #120
kez
kez's Avatar
finally in
can't find my transmission crossmember bolts anyone know the size and thread pitch
Quick Reply: Kez's 1992 Sc300 1jz Build
