Teal Mist 5 Speed Project
#273
Yeah, I didn't see the MKIII again today... But I did get the rotor off. I realized the two holes that where threaded into it had the hub right behind them, so I found two bolts and tightened them down until, pop, the rotor came off. From there it was simple and now I have all spacers on. I also found out I rub in the rear around corners so I took the fender lining out and will see if that fixes it.... if not, then a little pounding willl... On to pics!
Got new HID headlights today as well!
It looks really good and I am happy. Now I need to get an alignment done, then I should be good to go. Also please excuse the dirty car. No time to wash it lately. Any pic requests will be answered and I will grab pics tonight of the HIDs all on. Let me know what you guys think!
#274
Small update, tires still rub after taking out lining, so I used a rubber mallet to hammer in the lining where they were rubbing, since it was such a small amount. I will keep you guys updated on that. I think I'm gonna go out tonight and grab some pics w/ my 240 bud, so I will bring back some nice pics....
#277
Thanks man, my sister has a nice camera, so I borrowed that and was just messing around with it to see if we could get any good pics. I think Monday I might try it out again.
#280
I've had my steering wheel for a little bit, and decided to just put it on since I had a little time. Still waiting on the dash, but here are pics!
This is what comes with a Works Bell Standard Hub for the Toyota Supra, and it works perfect for the SC.
The steering wheel is a little worn, but it works nice! The horn hooked up perfectly as well. I also removed the airbag light on the dash, so no issues there.
#281
Got the dash and installed it. Now just need venting and airbag that will fit this dash, since my old one did not fit...
If anyone has any of the venting or and airbag (can be tan or black because I can paint it), let me know! Thanks!
#284
Small update. Got my dash trim....
Also, the vents from a pre-97 do not fit straight up to the 97+, so I did a little cutting and whatnot. But now I'm still on the hunt for a 97+ airbag, and I'm not sure what I am going to do next. Most likely, have some tint installed, and maybe some other small things that need to be done. I will keep you guys updated.
