Kwik's Black 09 build thread....
#76
I'm pretty sure people can appreciate both DIY's but TBH most people would not re-retro their car due to the fact that they will lose AFS. However it seems the task to change out the projector lens seems fairly straight forward, I just never saw the inside of our headlights personally before.
#79
I have some pics from another member that did them first on here. I kinda looked at his pics and just elaborate off of them. I think there is another member that just completed some with TSX projectors. I can't remember the link but I'll look around. Problems with this retro. The stock projectors on both the pre LED headlights and LED headlights have a side mounted projector. So when you do the retro you will have to cut a hole in the back of the headlight to remove the bulb or pry aparts the lights every time your HID bulb goes out. Other than that If you have done retrofits before mounting shouldn't be a problem. I'll look at home to see if I can find those pictures of how I mounted them.
HAHA. naw that was made by Arkym
Would you like a set by set on how I did the retro or set by set on swapping out the stock lens for the STI-R clear lens??
