DoomLight's 1992 SC300 1JZ Swap & Build Thread
#256
Resistor is resistor. Aaron is full of S. His product he sold you is full of S. And your amazing tuner and his shop are full of S.
Figure out how to get signal from the rear cam sensor, MAKE Aaron send you a new box and harness that he personally guarantees is 100%, and find a tuner that's gonna tell you 400whp is a bad idea on stock 1j injectors and refuses to do some risky attempt on something like that since it could blow up your car.
Then your car should work. If not, then it's your wiring. Good luck.
#257
Man it seems like everyone that builds there car today gets some kind of bull Shid run around I hope you get this worked out soon I would finda way to test the resistor to make sure it's working properly then from there find out if the aem is just messed up ( unfortunately your going to have to rip up that harness regardless smh)
Good luck
Good luck
#258
Ok so my next question is how do you want to run you injectors? btach or sequential ? i remember you said your tuner wants them to sequential?!
If so just get on from an Acura Legend $10 and just cut the pigtail all the way back so you can just plug it in you harness once you rewire the pigtail.
Wiring harness i would go through it again just to make sure everything is on point.
#259
so i got my 2jz resistor
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1574.jpg)
pulled out the harness. what a biotch!
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1575.jpg)
had it modified from batch to sequential
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1568.jpg)
here are the newly reloomed wires
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1569.jpg)
here is where the 2jz resistor was wired into the main harness.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1570.jpg)
this is where the 6 injectors come out of the main harness and patch into the driftmotion harness adapter.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1573.jpg)
here is where the join into the adapter.
and here is the last pic of the adapter from driftmotion. modified greatly of course.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1572.jpg)
i'll post up a pic once i reinstall the harness and put back on some of the plastic covers.
#260
update.
today after a few adjustments to the AEM, the car is alive again. now running sequential injection with the 2jz injector resistor.
while running. we checked the temps on the primaries of the header. the front 3 were around 450 degrees, but the rear 3 were only at 220 degrees.
weird. but i no longer have ignition break up past 4000 rpms. so next stop. getting it back to the tuner. i think this will be all over and i can finally get some horsepower out of this thing.
#263
1JZ Single SC400
Vrank, I think you need to be hired tuner and wire figureouter on here!!! You and Quick really knows whats going on on these things..
I wish I could have been more help, but as many of you know that wiring is not my cup of tea on harnesses. Other things yes, but harnesses, a no go in my book.
Keep us posted on what you finally do and the numbers that you achieve. You know we need to see a dyno sheet or video too!!! Good luck man...
#264
we did just get it running only. so thats probably why its all messed up.
#265
learning a lot about a cars systems now.
#267
a small update.
got my car down to the dyno. they finally got my car running right. the last 3 cylinders that were running cooler were simply not getting fuel. the injectors werent firing. which explains why they were 200 degrees cooler than the front 3 cylinders.
anyway. moving forward. they found another problem tho. not sure if its because I bought one of those eBay 255 pumps from TRE performance or what. but the tuner says the pump isn't keeping the fuel pressure despite my aeromotive fuel pressure regulator.
im not in Miami i live 110 miles away. so i cant see what they are doing. but they are giving me updates.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1588.jpg)
i'll post more updates
#268
Damn , it's always something lol . But it's good they are going through the setup and eliminating whatever doesn't work or not working .
I have a brand new tt denso FS if you are interested.
GL
GL
