DoomLight's 1992 SC300 1JZ Swap & Build Thread
#273
Ok i have another update....
Man im cursed with this car.
According to the tuner:
1. My tank has rust
2. The first pump I had was Chinese garbage
3. One of my injectors is either bad or not working so well
4. The fuel pump they put in was some run of the mill AutoZone pump just to get it running.
It made 383hp
He assures me its good at this level till I address these issues
So I have to replace the gas tank. I also plan to get an aeromotive 340 lph. Install new fuel filter.
Lastly I am going to have injector clinic clean and flow test my injectors.
This has to be it... ugh
This project is kicking my *** so damn bad
1. My tank has rust
It made 383hp
#276
Man, I just spent a couple hours of my work day reading through the thread and I gotta say its a great build. It sucks that you had so many little issues along the way, but I want to know how it ends. Everything good? Retuned?
#278
Awesome man , just spent the better part of my evening reading every post from start to finish.
Its inspiring to see this detailed of a build.
Im also one wanting to know the verdict lol those gremlins get fixed ?
#279
really haven't done much to the car. im kinda broke.
i have installed coilovers thats about it. im gathering funds for a set of BC264 cams and the bigger fuel pump and lines im going to need. i'll have it done in 2 or 3 months.
right now. since i've decided to drive it with the horsepower it has now.
i developed a leaky power steering rack, my a/c compressor has no suction and last but not least i have an exhaust leak. i gotta find it and fix it. can't have it dyno tuned with a leak. makes a nice car sound like crap.
#280
i picked these up on wednesday. the guy never installed them. were still in the box for an easy 600 bux.
these are the Megan Racing EZ Streets Coilovers 15 way adjustables.
![Name: IMAG1886_zps303d70c1.jpg
Size: 41.8 KB](https://www.clublexus.com/forums/attachments/build-threads/428946d1501342096-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1886_zps303d70c1.jpg)
![Name: IMAG1887_zpse79d9cfc.jpg
Size: 44.8 KB](https://www.clublexus.com/forums/attachments/build-threads/428947d1501342096-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1887_zpse79d9cfc.jpg)
i didnt take many pics of the installation progress. it was kind of a pain. didnt want to scratch the paint and so on.
![Name: IMAG1895_zpse5af85d6.jpg
Size: 54.8 KB](https://www.clublexus.com/forums/attachments/build-threads/428948d1501342096-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1895_zpse5af85d6.jpg)
![Name: IMAG1892_zpse1f717ab.jpg
Size: 49.5 KB](https://www.clublexus.com/forums/attachments/build-threads/428949d1501342096-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1892_zpse1f717ab.jpg)
![Name: IMAG1891_zpsaff7f14b.jpg
Size: 40.2 KB](https://www.clublexus.com/forums/attachments/build-threads/428950d1501342096-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1891_zpsaff7f14b.jpg)
![Name: IMAG1890_zps29112cf3.jpg
Size: 75.9 KB](https://www.clublexus.com/forums/attachments/build-threads/428951d1501342096-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1890_zps29112cf3.jpg)
#284
i also developed a crack in my exhaust manifold. great thats all i need. its cracked at the collector too. for now im just going to remove it and have it fixed. future plans include.. .
1. going to a T4 manifold from driftmotion.
2. ordering a .82-.86 A/R T4 hotside for my GT35 turbo. (i refuse to purchase another turbo)
3. i will have to have my downpipe remade for this. ugh...
i think when i do have THIS manifold fixed. im going to add extra bracing around the collector to ensure it last long. i dont even have 1000 miles on this manifold and it already cracked. i believe however the high heat from the numerous DYNO tunes probably caused it to crack.
stay tuned. i'll be adding more in the coming weeks/months. then i'll have more pics to share.
#285
1JZ Single SC400
Good to see that you have continued to stick with it. I wonder how loud that fuel pump is going to be?
If you decide to possibly need a quick spool valve, let me know, I have one.
