DoomLight's 1992 SC300 1JZ Swap & Build Thread
#304
time to take it apart!
![Name: IMAG2406_zps2a0fba4e.jpg
Size: 90.5 KB](https://www.clublexus.com/forums/attachments/build-threads/428029d1501334835-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2406_zps2a0fba4e.jpg)
good ole stock 1jz cams.
![Name: IMAG2407_zps0d4cd57a.jpg
Size: 83.3 KB](https://www.clublexus.com/forums/attachments/build-threads/428030d1501334835-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2407_zps0d4cd57a.jpg)
![Name: IMAG2408_zps8f7cfbf3.jpg
Size: 78.3 KB](https://www.clublexus.com/forums/attachments/build-threads/428031d1501334835-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2408_zps8f7cfbf3.jpg)
i already took the radiator out in this pic. so i could remove the crank pulley and other things in front of the timing covers.
breaking that crankshaft bolt was a mother! i put the car in 5th gear, pulled the e-brake, had my pops lay on the brakes, and had a pipe on the breaker bar just to break the 22mm crank bolt loose! whew!
![Name: IMAG2410_zps898de59b.jpg
Size: 69.8 KB](https://www.clublexus.com/forums/attachments/build-threads/428032d1501334835-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2410_zps898de59b.jpg)
and there you have it. fully removed everything. the timing belt was the original one, along with the cam seals and crank seal. decided to replace it all.
![Name: IMAG2413_zpsda193b55.jpg
Size: 64.6 KB](https://www.clublexus.com/forums/attachments/build-threads/428033d1501334835-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2413_zpsda193b55.jpg)
#309
anyway. finally took out the stock cams. boy these suckers hold alot of oil. I made a big mess on the driveway. when all the oil leaked out the oil feed holes in the cams.
here is a pic of them off the head.
![Name: IMAG2427_zps8a35ebef.jpg
Size: 92.4 KB](https://www.clublexus.com/forums/attachments/build-threads/428012d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2427_zps8a35ebef.jpg)
and here is a pic of them just sitting there before I torqued down the bolts. I used Permatex engine assembly lube so these cams wouldn't get any score marks during oil prime.
![Name: IMAG2428_zpsf4ef297b.jpg
Size: 82.1 KB](https://www.clublexus.com/forums/attachments/build-threads/428013d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2428_zpsf4ef297b.jpg)
cams bolted down and set at TDC.
![Name: IMAG2429_zps34ff7287.jpg
Size: 86.8 KB](https://www.clublexus.com/forums/attachments/build-threads/428014d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2429_zps34ff7287.jpg)
next cam seals were installed. since 1jz's were sold here. I looked on clublexus about which parts i could substitute to get this back together with new seals. I used V6 Camry Seals from a 1996 1MZ-FE. they protrude out a little more than the stockers. but they do the job. a standard 2jz crankseal worked for the bottom. it was really clean already, no leaks inside the timing area. but since i was there. i decided to replace all worn seals.
![Name: IMAG2430_zpsf236f6a4.jpg
Size: 82.2 KB](https://www.clublexus.com/forums/attachments/build-threads/428015d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2430_zpsf236f6a4.jpg)
#310
last pics...
Valve Covers installed.
![Name: IMAG2444_zpsfd27a060.jpg
Size: 112.8 KB](https://www.clublexus.com/forums/attachments/build-threads/428009d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2444_zpsfd27a060.jpg)
i bought brand new 5mm Hex Head M6x1.0x25mm bolts to replace the screws. cleaner look yanno?
just finishing up the engine. new oil and filter, antifreeze. yanno basic stuff.
![Name: IMAG2445_zpsb7009bfd.jpg
Size: 91.5 KB](https://www.clublexus.com/forums/attachments/build-threads/428010d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2445_zpsb7009bfd.jpg)
ready to fire her up and see if She sounds different with these cams.
![Name: IMAG2447_zps5606a6bb.jpg
Size: 96.2 KB](https://www.clublexus.com/forums/attachments/build-threads/428011d1501334810-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag2447_zps5606a6bb.jpg)
here is a Video. it really doesn't sound different from stock. i know the differences between stock and these stage 2 cams wasn't very much. but hey. who doesn't like a 35 second video.
#312
Really nice man. Good thing about those 264's, they sound stock but a good power increase. I have a soft spot for nice low lopey idles so I wouldve saved and picked some 272's or 280's up lmao.
