Build Threads Details on Club Lexus SC owner vehicles
DoomLight's 1992 SC300 1JZ Swap & Build Thread
Old 08-02-13, 10:50 AM
  #316
BAD954BOI
BAD954BOI's Avatar
In for results either way the cams should open up some extra power
Old 08-03-13, 10:19 AM
  #317
DoomLight
DoomLight's Avatar
well here are the results.
444whp @ 25 psi
sorry the graph doesn't show revs. it was really hot in th shop so the low numbers are due to the excessive heat. even with the Fan blowing on the front. it wasn't enough. too much spark knock. i also may have to change my back housing to something larger like a .96 i'll worry about that after I get some idea's from you experts.
about a 60 horsepower gain. which is noticable. but still short of that magical 500hp goal.
here is a video.
Old 08-03-13, 12:17 PM
  #318
gerrb
Super Moderator
gerrb's Avatar
25lbs of boost , is that on 93 pump gas ? Do you know what was the AIT temp that was logged in at that boost level ? Your mods should bring you to that target 500 of yours easily.
Old 08-03-13, 12:23 PM
  #319
DoomLight
DoomLight's Avatar
I know right but it was hot as ***** in that shop probably like over 100 degrees inside the intake tube with all of the heat soaking. I'm going to go back there again and try for ringtune and at the very least get all slightly larger back housing I don't think I need to change my turbo charger
Old 08-03-13, 12:46 PM
  #320
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Why is 500 your goal? Why not 650? JK
What was your power before the addition of cams? Under 400?
I wish I had driven an SC before the addition of the cams, so I can fell the difference.
Old 08-03-13, 12:51 PM
  #321
gerrb
Super Moderator
gerrb's Avatar
That turbo is rated up to 600. It's more than capable of giving you the 500 hp you need at 85% duty cycle and at the same time very responsive . What A/R do you have now .84 ?
Old 08-03-13, 12:57 PM
  #322
gerrb
Super Moderator
gerrb's Avatar
The effect of cams will be more at the higher RPMS, they give you more power at the top end.
Old 08-04-13, 11:20 AM
  #323
99SC42
99SC42's Avatar
Damn!! 25psi?
Who is tuning the car?
You need to fix your ignition..
What's the gap on your plugs?
That's alot of boost for that power.
GL
Old 08-05-13, 09:16 AM
  #324
wirelesstj
wirelesstj's Avatar
Originally Posted by Quicksc4
Damn!! 25psi?
GL
this. get some 1zzs, .028 gap and your good
Old 08-05-13, 08:11 PM
  #325
DoomLight
DoomLight's Avatar
gap at last check was .18
my back housing is .82
tuner said i need a larger back housing. he went on to say it was causing too much heat build up. pistons were getting hot.
the shop didnt help. no real air flow. it was really hot in there.
yes i know its a 600hp Turbo. but its not working out.. im already looking at a GT37r or GT40r with T4 flange.
it was 383hp, on stock cams, stock fuel lines and 19 psi.
Lance is my Tuner.
93 octane gas is what im using
500hp is the magical number! 444 feels good tho. but 500 would feel better.
spark knock was very high due to the extreme heat. i am considering getting a T4 with .89 a/r and a flange and have my current manifold modified. if this GT35r can still do it. it will make the power far better with a larger hotside.
i have 4 1zz coils. but i dont want my engine to look weird. yes its kinda lame to say that. but i've seen 800+ JZ engines with stock coils. so not doing that lol
Old 08-06-13, 05:15 AM
  #326
99SC42
99SC42's Avatar
Ok .18 is robbing alot of power..
Not sure why you went t3 from the beginning, this is an i6 not 4cylinder with 1.4 so you will be fine with a t4 turbo.
Ok you need an ignition amplifier if you don't want to change your coils.
They can make 1000whp on the stock coils depending on the ecu they are running and more than likely brand newcoils.
Gt40 is the worst pos you can ever buy , because they don't make any power.
Why don't you get a turbo that has been proven to work on the 1jz and made that power on the 1jz.
Hell Nate made 500whp on stock ecu with 60mm turbo and stock camshaft.
It's all about combination.
Gl
Old 08-06-13, 07:14 AM
  #327
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Does Quick know his stuff or what????? LOL
Old 08-06-13, 12:21 PM
  #328
wirelesstj
wirelesstj's Avatar
i would have to agree with quick. not sure, but maybe switching out the t3 manifold to a t4 and getting an adapter plate? not sure if changing the manifold would help with power or not. or just change to a t4 turbo. t3 turbos dont make much power, but with your set up, you should be at 500 or somewhere in the area. But you should def get an hks dli or something of the sort. and your gap should be bigger if your running more boost. my buddy is running .028 at 30 psi 722rwhp in his mk3 and no problems. hope this helps lead you in some direction
Old 08-06-13, 04:00 PM
  #329
BAD954BOI
BAD954BOI's Avatar
That turbo can make it and make it fast.. It's been proven even tho this is a 2j your 1j has the potential
http://www.supraforums.com/forum/sho...-GT35R-0.82-T4
Old 08-12-13, 10:01 AM
  #330
DoomLight
DoomLight's Avatar
thanks guys. so i should open up my gap to .24 maybe? and go T4?
just keep the turbo i have? i've been reading up and down all over the place and there are plenty of T3 and T4 powered 1jz that have crossed 500hp. so Im going to look into that.
i'll look into the amplifier box. as a last resort. but in the mean time i'll start collecting T4 parts.
LEXXIUM (02-03-19)
Quick Reply: DoomLight's 1992 SC300 1JZ Swap & Build Thread
