Build Threads Details on Club Lexus SC owner vehicles
DoomLight's 1992 SC300 1JZ Swap & Build Thread
Old 02-07-14 | 05:55 AM
  #406
DoomLight's Avatar
DoomLight
Originally Posted by jwin
how much was the motor set if you don't mind me asking? Looking to do a vvti 2jzgte in my sc300
i got it for a steal. the guy hooked me up. he sold me an engine without wiring harness, throttle body, a/c compressor, altenator, ignition coils, power steering pump and lower pans for 1500.
Old 02-07-14 | 05:58 AM
  #407
DoomLight's Avatar
DoomLight
Originally Posted by 99SC42
I was just hoping this doesn't happen to you...but i knew it was just a matter of time
I hate that clutch with passion, i've tried them all.. and i've lost 4 engines with that POS Clutch.
yeah i hate it when i dont listen. Vrank may have been right that my 1jz might of already been on its way out. i only drove it 2500+ miles with that clutch in it.
im looking at alternatives. single disc clutches around the 500 dollar and under range.
Old 02-07-14 | 06:27 AM
  #408
99SC42's Avatar
99SC42
No it wasn't on it way out , i drive my fresh setup with that PP for 2 weeks till i get my new clutch back AND when i got my clutch back , i decided to freshen it up again with a new Timing belt, and front seal since it started leaking and sur enough ..It destroyed my Engine again that was teh 4th and last..
Old 02-10-14 | 08:04 PM
  #409
14GS350F's Avatar
14GS350F
thats alot of work- well done
Old 02-13-14 | 05:08 PM
  #410
DoomLight's Avatar
DoomLight
update. no pics tho.
i sold my 1jz head, timing belt cover, bc264 cams.
i purchased a stage 3 clutch for now from F1 racing i got second hand that was never used. just to get my car going. i can easily change the clutch later.
i also purchased a new oil pump and some toyota silicone for the engine.
also i purchased new radiator hoses since the VVTI has that hump in the front.
a new vvti solenoid was needed. seems these are fragile and tend to break during transport.
luckily i also was able to score a 2jzgte (non vvti) upper intake plenum for my engine so i can retain the stock IAC.
tomorrow i should get my CXracing thick wall manifold. after i get the new oil pump installed and the lower pans swapped on to this 2jz. i should be able to drop the engine back into the car. i will try to take as many pics as possible.
i wanna sell my current 880cc low impedence injectors. going to get a top feed rail and some FIC 1100's. that should meet my goal of 600+ on E85 and be more than enough for 500hp on pump.
Old 02-15-14 | 07:32 PM
  #411
DoomLight's Avatar
DoomLight
today i pulled off the oil pan off the 1jz finally. needed to get the sumps off so i can get the 2jz together.
anyway here is what i found.
oh yeah. Crank walk from the 2800 lb pressure plate.
these were reduced to mere thin sheets of paper.
i didnt see any scorch marks on any of the rods. maybe it can be saved. who knows. i'll pop off the main and rods caps to inspect. if they are safe. then i'll get the block cleaned and put in some new thrust washers and sell it off.
Old 02-15-14 | 07:36 PM
  #412
DoomLight's Avatar
DoomLight
got a new oil pump.
installed it.
then i did the timing and put it all back together. i didnt take may pics today. i was on a time schedule. besides all i was doing was just regular maintence.
Old 02-15-14 | 07:38 PM
  #413
DoomLight's Avatar
DoomLight
lastly. i got the lower pans back on. after i pressure washed them then doused them in break cleaner. i flipped over the engine and reinstalled everything.
i installed the turbo manifold and rear turbo housing and left it there for the day. tomorrow or later next week i should be able to get back to it.
im trying to get FIC1100 injectors. or maybe go with the Bosch 1150cc top feeds.
Old 02-16-14 | 04:54 PM
  #414
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Sorry to see another issue with Crank Walk. It is getting more and more familiar with these ACT clutches. I get nervous every time I crank mine now, due to me reading more on them on here.
Old 02-20-14 | 07:59 PM
  #415
DoomLight's Avatar
DoomLight
yeah but i dont think you have the same pressure plate as the one i had. mine was the HD extreme. u might be safe if it didnt happen already
Old 02-21-14 | 09:35 PM
  #416
Abelo's Avatar
Abelo
ive got the act extreme clutch kit now im kind of getting scared about crank walk from all this talk...
Old 02-24-14 | 11:36 AM
  #417
DoomLight's Avatar
DoomLight
no bull****. it happened to my motor. pics are proof.
its not like it happened right away. took 2400 miles on the dot.
just dont get a pressure plate this strong. now i gotta try to sell it.
Old 02-25-14 | 10:48 AM
  #418
Kire's Avatar
Kire
Man that sucks! I'm glad I didn't go with them for my clutch setup. I hope my south bend setup works well!
Old 03-16-14 | 07:18 PM
  #419
snipez411's Avatar
snipez411
any advice on what all has to be deleted (oil lines ect.) or bought to single turbo the 1j?? (beside turbo man...)
Old 03-19-14 | 07:20 PM
  #420
DoomLight's Avatar
DoomLight
cleaned up the engine bay. got ready to drop the 2j in.
