DoomLight's 1992 SC300 1JZ Swap & Build Thread
#76
here is where i am now. the stock ECU is taking a crap on me. it doesnt have any leaky caps on it at all. it just doesn't wanna run the car after 15 mins. i keep getting code 14 and 41 after it warms up, not before.it also wont rev past 2000 rpms and even worse if i try to drive it. can't go past 5 mph.
i ordered the Drift Motion AEM! 1306 bux!
![Name: IMAG1296.jpg
Size: 142.1 KB](https://www.clublexus.com/forums/attachments/build-threads/431143d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1296.jpg)
dang all i got was peanuts!
![Name: IMAG1297.jpg
Size: 119.2 KB](https://www.clublexus.com/forums/attachments/build-threads/431144d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1297.jpg)
oh i found you hiding under there!
![Name: IMAG1298.jpg
Size: 118.6 KB](https://www.clublexus.com/forums/attachments/build-threads/431145d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1298.jpg)
got the jumper harness
![Name: IMAG1299.jpg
Size: 122.3 KB](https://www.clublexus.com/forums/attachments/build-threads/431146d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1299.jpg)
![Name: IMAG1302.jpg
Size: 181.1 KB](https://www.clublexus.com/forums/attachments/build-threads/431147d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1302.jpg)
serial and usb cables
![Name: IMAG1301.jpg
Size: 190.4 KB](https://www.clublexus.com/forums/attachments/build-threads/431148d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1301.jpg)
the star of the show!
![Name: IMAG1300.jpg
Size: 113.7 KB](https://www.clublexus.com/forums/attachments/build-threads/431149d1501353066-doomlight-s-1992-sc300-1jz-swap-and-build-thread-imag1300.jpg)
here is the AEM boost solenoid, just have to find a place to mount it.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1321.jpg)
here is the AEM 3.5 bar Map sensor.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1322.jpg)
and here is the AEM with the jumper harness attached. i put it on to test it, it works good!
but i haven't found a definitive how to on making the fuel pump kick on with this thing. im very cautious.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1323.jpg)
that pesky fuel pump ground is gonna be my undoing! anyway i only got it to run by jumping FP and B+ on the diagnostic port.
this is where i am up to now.
things to look for next...
pics of my 880cc injectors
pics of my 7mgte injector resistor and installation.
going to order AEM UEGO wideband.
stay tuned folks
stay tuned folks
#80
thanks it cost a lot! friggin pearl paint jobs are no joke!
after i get this puppy tuned to my 500hp goal. gonna get some coilovers. and think about an aftermarket radio. the cd changer skips like a kid playing hop-scotch because of the lowering springs.
#89
this is the front side. it was hardest because i had to get it under the turbo where it bolts to the manifold.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1324.jpg)
this is the rear. i apologise. there isnt a lot of room to take a picture.
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1325.jpg)
![](http://i77.photobucket.com/albums/j41/drwondereyes/IMAG1326.jpg)
#90
Is there a place to buy that t3 manifold, I am going through the same process as you but need a new manifold as the one I bought does not fit my turbo, hits the cam covers.
