DoomLight's 1992 SC300 1JZ Swap & Build Thread
#91
they sell it for 195 on their site. its hard to find this manifold on Ebay. its full of T4 Manifolds.
#92
i bought mine from www.SSautochrome.com yes they have a bad rep. from ebay. but im telling you. make sure you have the main flange to head checked before you put it on. it will leak i tell you!
Yep I think Ima go this one too because it seems to be the only one that will work for the price. But I'm looking at it from XSPower! They have it cheaper when it is shipped Internationally.
P.S did you brace yours? Got more photos of it installed?
#93
This one here. http://www.ssautochrome.com/search.i...QueryTitle=1jz
#98
So this one? http://www.ssautochrome.com/search.i...QueryTitle=1jz
Looks ok. I'm just concerned with the fact there is no angle on the t3 flange when it comes to downpipe. And what about overall strength, looks a bit weak to me :s Anyone else used these?
#99
90% of the turbod 1 and 2jz motors with single conversion have to have a 90 degree bend welded on. At least with this one its not necessary. Your only issue will be oil drain. I had to use two 90 fittings to clean the cylinder 1 thru 3 exhaust runners.
Look at the 2jz vvti build thread with a GT3582r you will see what I'm talking about.
I hope this manifold is stronger than the usual SSautochrome stuff. It says its made of 321 steel. Not the usual thin 304.
I didn't wrap the manifold nor did I use the garbage gasket it comes with. Those are potential problems I think I may have avoided thus far.
Stay tuned.
#100
That's correct. No angle. If you want an angled manifold you have to go T4. It's angled. And I'm certain the downpipe kits will work. If you switch to a T3 manifold VIA an adapter on the T4, that just makes you have height and clearance issues.
Stay tuned.
Stay tuned.
#102
i just dont like the noise of open dump on boost when im in a car like this.
#103
yes. the flange has 6 holes i assume for you to use a 4 bolt gate like the HKS type or the 2 bolt type like the Tial. the Tial i used with gasket fits perfectly. you should be ok. the space is kinda tight as you seen in my pics. so if you go open dump on the gate you should have room.
