1jz vvti build....flippy dipping finnaly!!!!!
It really depends on what year Supra mounts your are using?
if you are using the 93.5-96 mounts you will need to change the brackets.
97-98 mounts are just like the stock sc mounts but a little stiffer and have metal casing on them.
12360-46111 is the part number for the 97-98 tt mounts, ill have pics up today, I had to saw zaw my stock header off, the bolts at the mid pipe were frozen. Installed my Toyota camry/corolla throttle cable today. Gonna clean up the bay tonite, throw the mounts on, and do some work.
ok, added a few pics, had a question, what the hell do i do with that vac pump? if thats what it even is, i mean it does say act vac on it. the cut wires are to the fuse box, which i already cut off of my old harness.
