Build Threads Details on Club Lexus SC owner vehicles
1jz vvti build....flippy dipping finnaly!!!!!
Old 06-09-12, 05:27 PM
  #31
JDMb16bEG6
JDMb16bEG6's Avatar
I pretty much have everything down packed, I've been reading up on this swap for 2 years now, I have like 40 book marks of everything needed to do the swap, and I'm also an ASE certified mechanic, also have my Pennsylvania emissions and safety inspection license. Hopefully the motor will be in tomorrow, kez if you readin this you should come through tomorrow if you want to see what's involved and lend a hand, ill pay you in alchol if you would like.
Old 06-09-12, 07:03 PM
  #32
kez
kez's Avatar
lol i would if i was in town im on a mini vaca down the shore
Old 06-12-12, 01:55 PM
  #33
JDMb16bEG6
JDMb16bEG6's Avatar
i need to know what this is? vacume? coolant? and where does it go to?
Old 06-12-12, 01:56 PM
  #34
JDMb16bEG6
JDMb16bEG6's Avatar
Old 06-12-12, 02:50 PM
  #35
StiCk3
StiCk3's Avatar
looks like the coolant drain plug for the engine block. Nothing you need to worry about, just make sure it's sealed
Old 06-12-12, 03:36 PM
  #36
JDMb16bEG6
JDMb16bEG6's Avatar
Under it the nipple
Old 06-12-12, 03:38 PM
  #37
JDMb16bEG6
JDMb16bEG6's Avatar
It looks as if a hose is supose to be there
Old 06-12-12, 03:53 PM
  #38
88supramki
88supramki's Avatar
Agreed with Stick3, pretty sure it just needs to be sealed
Old 06-12-12, 04:02 PM
  #39
kez
kez's Avatar
Rainy day is this in
Old 06-12-12, 04:22 PM
  #40
JDMb16bEG6
JDMb16bEG6's Avatar
Not in yet, went to put my clutch release bearing and that little clip that holds it to the fork was wrong, it was for an mk3 or 4, anyway I just picked up the right one from lawernceville lexus for 5 bucks, then I can get the trans on tomorrow
Old 06-12-12, 04:43 PM
  #41
99SC42
99SC42's Avatar
It doesn't need to be seal , that bolt on the top is a 14mm if you loosen it up all the coolant that's in the block will come out through that nipple.
So as long as the bolt it tight you are fine. So drain the block and get all the old dirty coolant out before you fill up the sustem with new coolant.
gl
Old 06-12-12, 04:51 PM
  #42
JDMb16bEG6
JDMb16bEG6's Avatar
Ooooooooooo ok, so there for I do not need to do anything with that nipple then? I thought I had to run a hose to somethin, but I guess not? Are you 100 % sure?
Old 06-12-12, 05:08 PM
  #43
99SC42
99SC42's Avatar
2000% positive .
Old 06-12-12, 09:28 PM
  #44
DoomLight
DoomLight's Avatar
i guess the VVTI blocks have that. i never noticed it looking that on my regular 1jzgte block.
Old 06-13-12, 07:35 AM
  #45
88supramki
88supramki's Avatar
I know this is a stupid question, but shouldn't all blocks have that feature?
Quick Reply: 1jz vvti build....flippy dipping finnaly!!!!!
