JDM RHD Toyota Soarer 1JZGTE Single Turbo Build
1JZ Single SC400
I think with that turbo you should be way upwards to your goal and plenty of left over, as long as you have the fuel setup and so on. Why dont you add some BC stage 2, 264's cams? I have heard these alone are good for around 50 HP. Drop and play, use the stock retainers and valves and so on. Just leave the stock shims where they are.. JMO.. I am subscribed.
Yep no response from anyone at xspower ssautochrome about a tracking number. Kind.bb of annoying how they think it is ok to ignore your questiins AFTER you purchase an item. If it took 7 days to get to you from China it should be about the same or less for me then. Will see.
i paid about 35 dollars. the shop welded 2 bars from the exhaust flange to the turbo flange. i am hoping i dont have any issues when i start to drive it regularly...
the wastegate pipe has no reinforcements. however the wastegate is recirculated back into the downpipe on my setup. there is also a flex section in my design. it should be sturdy enough to resist cracking.
crossing fingers.
crossing fingers.
