My 1991 Toyota Soarer 2.5GT
#62
Buying a new car.... decided to hold off going big single and just going to clean things up on car
Driftmotion pulley set
new VC gaskets and flywheel inspection plug
Mishimoto Rad and e fans
Marlin crawler shift bushings
Custom Straight pipe exhaust ( no muffler or res 3" SS ending in a 3' long 4" blast pipe )
Custom paint job in engine bay while engine is out
Vertex front bumper
oh and found this locally so why the hell not
TRD Y pipe
Vertex front bumper
TRD Y pipe
#64
this thread was a treat to read haha happy to see more soarers in Canada !
you tho have done way more to yours them mine :P im loving the bay so clean !! Where did you snag those blue rad hoses? super clean car tho!!! If I ever see you around Manitoba ill have to check it out in person
#65
Rad hoses were mishimoto but i see www.driftmotion.com carries them as well in a couple different colors.. they are great to deal with
few things came in
Driftmotion pulley set only running DM crank pulley till i boost power beyond 400whp.. after that ill switch to a fluidyne
R154 shifter bushings
1jzgte valve cover gaskets
R154 flywheel inspection plug
and a fresh 3" exhaust gasket
few things came in
![](https://sphotos-e.ak.fbcdn.net/hphotos-ak-ash4/c67.0.403.403/p403x403/306170_10151517303713638_502225935_n.jpg)
#67
mine i filled the one hole.. can barely tell eh, but when you order true vertex peices you can order it open left, right or both.
see your in jersey... ever hit the East Coast Bash
#68
#70
so you take my engine bay and remove this
![](https://sphotos-a.ak.fbcdn.net/hphotos-ak-ash3/p480x480/5283_10151579001228638_185656614_n.jpg)
that big nasty engine bay chassis harness along with fuse box
leaves you with a bay looking like this
![](https://sphotos-d.ak.fbcdn.net/hphotos-ak-ash3/p480x480/32619_10151577722353638_96543832_n.jpg)
Ill post better pics with the relocation of the fuse box and what i had to change / extend once its a bit cleaned up... as it sits right now tho in that last pic and harness is back in and everything hooked up wire wise...
Next up is painting the engine bay, installing aluminum pulley set, shifter bushings, new MT90 redline tranny fluid, whiteline steering rack bushings. Currently working on new exhaust for car as well
#71
3"-4" reducer welded onto my 2' long 4" SS blast pipe
![](https://sphotos-c.ak.fbcdn.net/hphotos-ak-ash4/482224_351547894945253_508548090_n.jpg)
its being tig welded up by a friend check him out on facebook hellafab
also a snap of one of my wheels.. looks cool
![](https://sphotos-a.ak.fbcdn.net/hphotos-ak-prn1/p480x480/65367_351247928308583_1227912477_n.jpg)
