"Raine's SC300 (KEIRA 2.0) From the Beginning to End."
#214
Oh man... "a lot" is an understatement. There was a lot of overspray, but there were also (and worse) a lot of parts that were completely painted that shouldn't have been.
There was paint overspray on the edges of the low-beam headlamp lenses, the edges of the high beam headlamp lenses, the side windows, the taillights, and the muffler tips. Worse, there was COMPLETE paint coverage on the rubber seal on top of the headlamps, the rubber seal at the front signal lamp edge, the rubber seal at the front of the hood (underneath when you open the hood), the rubber seals around the windshield sprayers, the entire black trim piece that surrounds both side/rear windows, the whole rubber seal at the bottom of the doors, the whole rubber seal at the back edge of the doors, the rubber seal around the door handles, the left side keyhole, the rubber covers at the door latches, the whole black surround on the moonroof, and most of the plastic antenna base. There's probably more, I just forgot the rest.
It took a lot of work to clean all of that crap up. The overspray was relatively easy to remove (acetone, a rag, being careful) but the parts that were actually sprayed, either I had to buy all replacements (nope) or sit there with an Xacto and chip it all off (yup). For about 10 days after I got my car that's all I was doing. It was such a pain in the ***.
#216
09.11.12
Nice Rack
- After the miles and miles of daily driving, the front end developed a knocking noise. It was the signal to replace the lower control arm bushings. Since that meant the car had to go up, I decided to combo the job with a new steering rack and new outer tie rods. Felling a little "road trip" I headed south to KingPhilip's and we started with the LCA bushing replacement.
Front bumper off - the only way to get a jack under the car.
Torching out the old, dry, broken LCA bushings.
The only hard part about this is keeping from inhaling the burnt rubber smoke.
It took about 10 minutes with a constant burn to remove each bushing completely.
New (reman) rack on the left, old, leaky, ripped boot rack on the right.
We were chasing daylight so I forgot to take more pics. The whole job (replacing the front LCA bushings, swapping out the rack and tie rods) took about 7 hours, with a break or two in between. LCA replacement bushings were from Prothane, and we only swapped the lower bushings; I still have the Prothane upper bushings in the box for future use when needed. Thanks to KingPhilip again for handling the bulk of the labor (I'm over working on my car all the time LOL).
The next day I headed out to the only place I recommend for lowered car alignments - JC Autohouse in Temple City, CA. Cyrus, cheery as usual, wrenched on the car and adjusted everything to my custom alignment specs, and he took care of centering the steering wheel as well.
I only show up once or twice a year, but every time I'm here Cyrus remembers me.
Best shorts EVAR LOL - Cyrus rolling up the jean shorts because of the hot weather in 626 hahaha.
With the wheel steering centered and the alignment perfect, the car has a whole new feel to it. First of all, no more power steering leaks! As for the LCA's, the front end doesn't have any squeaks and knocks anymore, and when going over bumps and stuff on the road the front suspension feels nice and tight. I would have to say that upgrading LCA bushings makes a HUGE difference in handling and everyday driving comfort and feel.
Cyrus got it to my requested specs - wheel lips aligned to the front fender.
...and the rear wheel lips match the fitment of the front.
(continued on post #246)
Nice Rack
#224
Are the ball joints in good shape on your LCA's ? The reason I ask is because my LCA's need to be changed. If I can swap the bushings alone and have a good ride quality, then i'd change the bushings for pro-thanes and call it a day. New LCA's are way too expensive.
Inspiring thread BTW.
#225
