Build Threads Details on Club Lexus SC owner vehicles
SC400 project w/6speed from 350z
Old 07-11-12, 09:56 PM
sc4doubleO
sc4doubleO's Avatar
Default SC400 project w/6speed from 350z
10 characters
Old 07-11-12, 10:08 PM
97-SC300
97-SC300's Avatar
Very interesting. Did it fit the tunnel without major work?
It seems much longer than the auto. Where is the shifter coming through at the center counsel?
Old 07-12-12, 01:16 AM
CalitriSC
CalitriSC's Avatar
That will be pretty nice when finished.
Old 07-12-12, 03:26 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
It's good to see you were finally able to get started on this project. It looks like an interesting build.
Old 07-12-12, 04:16 AM
skirts
skirts's Avatar
Awesome project!
Old 07-12-12, 04:26 AM
92Garntprl
92Garntprl's Avatar
wow that's is amazing....and you made it seem so simple..I wan't
Old 07-12-12, 05:00 AM
stockhatch
stockhatch's Avatar
Nice work! I am interested in this as well, though.^^^^^
Old 07-12-12, 05:01 AM
DoomLight
DoomLight's Avatar
yeah good question. thats a big transmission. the V160 getrag looks smaller compared to that thing.
Old 07-12-12, 06:08 AM
99SC42
99SC42's Avatar
the shifter housing is longer than the V160 , the V160 is wider and heavier.
That shifter housing will be modify to fit in the auto shifter hole, just cut the tripod and shorten it up. Same scenario when u are doing a V160 swap in the SC, 240sx and IS300 because the shifter sit back and the shifter hit the shifter trim in 2,4,6 and R.
i am sure not massaging is required because the v160 is wider and doesn't require any massaging.
Nice OP! What clutch are you running? I can't wait to see it.
Old 07-12-12, 07:10 AM
megamax
megamax's Avatar
so (how cheap) was that 350z tranny??
Old 07-12-12, 07:21 AM
empera
empera's Avatar
are you using the 350z flywheel and clutch set up?
also would you be able to get more pilot bearing "adapters" made?
awesome project!
Old 07-12-12, 08:35 AM
bigmalik00
bigmalik00's Avatar
I got my popcorn for this one.
Old 07-12-12, 08:46 AM
account2x
account2x's Avatar
Originally Posted by Quicksc4
tThat shifter housing will be modify to fit in the auto shifter hole, just cut the tripod and shorten it up. Same scenario when u are doing a V160 swap in the SC, 240sx and IS300 because the shifter sit back and the shifter hit the shifter trim in 2,4,6 and R..
The supra 6 speed doesn't hit the trim in a sc300.
Old 07-12-12, 09:03 AM
lilSCsteve
lilSCsteve's Avatar
Me too! Definitely worth watching!
Old 07-12-12, 09:22 AM
sc4doubleO
sc4doubleO's Avatar
its a tight squeeze when installing since the bellhousing is large. Once bolted fits great.
Quick Reply: SC400 project w/6speed from 350z
