GFM slow and steady "build"
I trimmed my bumper tab too and went lower but once I did, there's something else that I started to rub on.
It's this black metal piece that looks like it was connected to the bumper tab so you might have to shave that a bit too.
I haven't gotten around to it but that's what one member suggeste to me.
Not sure if it's different because you have an '09 and I have a '10.
Otherwise, your car is looking great!
I'm not sure what your wheels specs are because I did a quick skim through and saw this! Just a heads up
Otherwise, your car is looking great!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Im no stranger to having to cut / weld whatever is needed to get lower my old jetta: (had to notch the frame on both sides for axle clearance and tie rods)
![](http://i15.photobucket.com/albums/a368/metallicastar/MK4/4367524122_110db6bc6d_o.jpg)
![](http://i15.photobucket.com/albums/a368/metallicastar/MK4/juice%20an%20wires/_DSC0492.jpg)
![](http://i15.photobucket.com/albums/a368/metallicastar/MK4/juice%20an%20wires/_DSC0013.jpg)
Are you using a DIY walk through to remove your headliner or are you just going at it? Did you encounter any problems with just wrapping it? You would use adhesive fabric spray and then tuck the excess into the trim right?
Not using a DIY, just experience from doing other headliners
As I see it, these are the parts / part numbers you would need to do the black headliner swap.
These parts come from the IS F / ISx50 F-Sport, and I've tried to be exhaustive, but the roof console has a lot of choices, but I've tried to make it simple.
63311-53130-C0 - Headliner without Sunroof
63311-53150-C0 - Headliner with Sunroof
62211-53040-C2 - Garnish, A-Pillar RH
62212-53040-C2 - Garnish, A-Pillar LH
62411-53061-C1 - Garnish, B-Pillar RH
62412-53061-C1 - Garnish, B-Pillar LH
62471-53051-C1 - Garnish, C-Pillar RH
62472-53051-C1 - Garnish, C-Pillar LH
74310-53210-C2 - Sunvisor RH
74320-53230-C2 - Sunvisor LH
74317-60020-C0 - Sunvisor Screw Cover (Qty: 2)
74348-12040-C0 - Sunvisor Holder Hook (Qty: 2)
74610-53030-C0 - Roof Grab Handles (Qty: 4)
74605-53010-C0 - Rear Coat Hooks without Sunroof (Qty: 2)
74605-53020-C0 - Rear Coat Hooks with Sunroof (Qty: 2)
73210-53360-C2 - RH Seat Belt without Pre-Crash System
73210-53380-C2 - RH Seat Belt with Pre-Crash System
73220-53270-C1 - LH Seat Belt without Pre-Crash System
73220-53280-C1 - LH Seat Belt with Pre-Crash System
81360-53010-C0 - Rear Spot Light
Roof Console Box:
81260-53270-C0 - 06-09 Without Microphone, Without Sunroof
81260-53290-C0 - 06-09 With Microphone, Without Sunroof
81260-53050-C0 - 06-08 Without Microphone, With Sunroof
81260-53600 - 06-08 With Microphone, With Sunroof
81260-53390-C0 - 09 Without Microphone, With Sunroof
81260-53400-C0 - 09 With Microphone, With Sunroof
81260-53830-C0 - 10-12 with Microphone, without Sunroof, without Safety Connect/SOS
81260-53A40-C0 - 10-12 with Microphone, with Sunroof, without Safety Connect/SOS
81260-53A50-C0 - 10-12 with Microphone, without Sunroof, with Safetye Connect/SOS
81260-53A60-C0 - 10-12 with Microphone, with Sunroof, with Safety Connect/SOS
Jeff
Roof Console Box:
Jeff
Stance and possible wheels are anything but simple and elegant. *confused* Nice color though.
It's the type of wheels and level of stance, both of which stand out and are aggressive. Elegance and simplicity is traditionally subtle, conservative, timeless, and restrained. You are going for sporty look that stands out.
your definition of elegance and simplicity is more or less what will happen. ie. no lip kits. nothing unnecessary.
the wheels pictured are the LEAST sporty or agressive wheels ever. simple classic 5 spoke design. (although they have since been sold)
aggressive fitment and low does not automatically equal sporty.
IMO ccdan has a prime example of simple and elegant
![](http://farm8.staticflickr.com/7162/6706268141_ac12972297_b.jpg)
less is more. you will see
