My 97 sc300 build
#32
Pretty excited maybe I can have time to finish stage 1 this week. Still waiting on brake lines and 96 5 speed ecu. Diff is in the car. Brakes are ready to go beside waiting for brake lines to come in.
Stage 1
98 steering wheel
New used driver seat
Auto to manual swap r154
Full tune up
Auto tt differential
Clear headlight
Tt wheels
Ls400 brakes
Ss brake lines
Fix body with new rear bumper.
Stage 2
Na-t
Stage 1
98 steering wheel
Full tune up
Clear headlight
Tt wheels
Ls400 brakes
Ss brake lines
Stage 2
Na-t
#35
Stage 1
98 steering wheel
Full tune up
Clear headlight
Tt wheels
Ls400 brakes
Ss brake lines
Stage 2
Na-t![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Stage 1
98 steering wheel
Full tune up
Clear headlight
Tt wheels
Ls400 brakes
Ss brake lines
Stage 2
Na-t
Stage one sounds almost exactly how my car started out. I remember years ago, I was one of the first to do an R154 swap on an NA car and people thought I was crazy and kept asking why did you go R154 and not W58 since the car was still on the stock GE. Now it seems like R154 is the norm since people realize swapping in a W58 is a waste of time if you plan on going the turbo route.
You're gonna like the R154 and 3.76 combo, it's alot of fun, even without a turbo it's so much nicer than the slow shifting auto. And those TT wheels + LS4 brakes are also going to put a big smile on your face when you see how much better the car handles and stops over stock.
Good luck!
#40
So yesterday I finish my car put my car back on the ground. Started it up and I couldn't disengage the clutch to put it into gear. So I put the car back on jacks took off the inspection cover and the slave cylinder rod could be pushed back with my hand and the pedal was really light. The slave cylinder rod moves with the pedal too but not enough force to move the hub. After some research this morning I believe that it cause I didn't bench bleed the new used clutch master. Has anyone else had this problem?
#44
Adjust the rod for the clutch master? Do you make the rod shorter and longer and what does that do to the slave cylinder. The rod in my slave cylinder moves but it's not enough to pull the hub back to disengage the clutch. I didn't bench bleed it when I installed the clutch master. The clutch pedal is feather soft.
