My 97 sc300 build
#48
Your car was auto and you convert it to manual, you will have to adjust the rod that comes out the master cylinder to the pedal.
it's does have enough travel , that's why you can't put it in gear when the car is running.
#57
Just a pain to pull the transmission out considering I do it in my garage by myself but it will get fix soon. I was wondering why it was hard to put on the bolts to the pressure. Just thought the dowel pins was causing that. Guess it was the clutch disk. Hope I didn't bend it.
#58
Wasn't that bad to take the tranny out. Took me roughly an hour and a half. Waiting for a new OEM pressure plate and clutch disc. I put a used one when I first installed the tranny. Guess it a good idea to put a new one in since I'm already in there for the second time. I might be driving this car stock for awhile considering funds are low.
#59
Reinstalled the clutch disc the correct way. Only thing left is to install the exhaust and driveshaft. Hopefully this solves my clutch not disengaging. My friend has a set of iforged seneska off his g35 that he wants to sell. Do you guys think they will fit the sc? They are 19x9.5 and 19x10.5 offset unknown but they sit flush on the g35.
#60
Looking good so far..... keep it up!. Btw ive heard that by baking the headlights in an oven, then removing the front lens and spraying it down with plexi glass cleaner also gets you a clean look.
