My SC300 NA-T Build
#31
I understand it's a lot to fix a previous owners hacks, but why are you buying LSD pumpkins when there is about 100hrs of wiring work?
Plus you live close to Aliga he has a gajillion parts sc's in his yard.
Priorities will get it squared away, good job on the A/C so far.
#32
Update: Got the car started on Sunday. Changed oil, put new Toyota Red coolant, and TRD thermostat. Car was running well. Monday night (last night)- while cruising at 45mph in 5th gear, car just dies and didn't want to fire back up. Didn't have any tools or anything to check anything with. Called tow truck to bring me home. Not sure what it is, it could be really simple, but I'm pretty much done with this car. Maybe I'm just livid at the previous hack ups, but with the money I spent on the car, I could have supercharged my G and have a more reliable car.
I'll get the car running and putting her up for sale. I'm definitely going to end up selling it at a loss, but hopefully find an owner who has more time and patience than me.
Jeremy
Jeremy
#34
To be honest you will always have a electrical diamond effect if you don't get to the root of your issues.. It's easier to start fresh then to try to better rig someone's hack job.
In your sig I see you want the sc to be a track car?
How about taking out all the unnessaray stuff you got in there and eliminate the f'd up wires at the same time?
But, you want it to be a full car just hit up "aliga" who is a member on the forums and get a quote for the harnesses you need to actually figure out if its money your willing to spend.
Just my .02
Just my .02
#35
Just my .02
Just my .02
#36
wow bro. I saw this car for sale a long time ago and it seemed a bit fishy.. didn't think it had THAT much work. If I was you id give it one last attempt. Take a break from the car, and then dedicate a weekend to it. Start with the wiring. Then head to the other cosmetic ****. Gazi lives here and we can get a **** ton of used parts for cheap.
#37
#40
And majority of the Op issues are on the radio harness so far, easy to replace! and it's not like when you are buying your car you gonna ask the seller to pull the radio out so you can see if the harness has been hacked up
#41
Sorry it's just *modded cars* it could be a bone stock car as far as i know, if the PO like to halfas$ stuff that's what you get.
but what it is.
#42
Car is back up and running.... Culprit? Loose ignition wire... wire was wrapped around a post terminal and was loose. It's just so ridiculous how annoying the issues are...
Anyways, how dirty is your brake fluid or clutch reservoir?
![](http://i257.photobucket.com/albums/hh235/SUPRAman97TT/94%20SC300/IMAG1450_zpse0455119.jpg)
![](http://i257.photobucket.com/albums/hh235/SUPRAman97TT/94%20SC300/IMAG1448_zps1b6791be.jpg)
Also, I thought my seats were embroidered with the Lexus logo, actually just hot glue... noticed it earlier when the temps got warm...
![](http://i257.photobucket.com/albums/hh235/SUPRAman97TT/94%20SC300/IMAG1458_zpsdce3a08a.jpg)
Working on it some more this weekend...
Good news is, I have been busy planning the winter build
#43
No disrespect but did you actually look at this car before you bought it? test drive ? check it out during daytime?
this is ridiculous seriously ..
and did you talk to the previous owner every since you bought this car from him?
#44
Yeah, actually I did. From what I saw, mostly cosmetic since car sat uncovered for months at a time because owner worked overseas. The fluids were a little dirty, but didn't think much of it since it's something I can do on a weekend. I was planning on upgrading a lot of stuff. Also, he had someone remove stuff (dvd player, carputer, etc) right before I bought it due to a misunderstanding, but assured me everything would be removed correctly. It ran fine actually when I saw it, but of course, I couldn't remove every electrical tape or take apart the dash. And, no I have not talked to the owner since finding all these things, but like I said, electrical half *** is what I cannot deal with. It's the only reason I've been left stranded.
#45
Small bump to my thread. I haven't posted in a while, but I've been busy.
Supra Auto TT LSD has been installed. New rear TT brakes set up installed. I've purchased the following and are ready to go
New summer tires- Sumitomo HTR ZIII 245-40-18 and 275-35-18
Oil Cooler set up- Using an Earls with Mocal thermostat
Power steering cooler- Using a large B&M unit
Fluids- MT90, Heavy Shockproof, etc
New Corbeau A4 with bracket for driver's side
Cryo'd Brake Rotors from frozenrotors.com
Hawk HP + pads for the TT brakes set up
97 side skirts.
Will be posting more info and pics soon.... it's been getting very pricey lol and I still need an R154 (maybe next winter), new exhaust, some suspension components (next winter too) etc.
Hopefully get it on the track by July
97 side skirts.
