Awesome stuff man... Cannot wait to see the result!
Also, quick question for ya... What did you do to the fender liners front and rear? I need to either remove them, cut, or modify them somehow and I wanted to ask to see what you did.....some have been telling me to remove it all together and spray the inner fender with some of that rhino liner stuff just to prevent dirt and rust from getting up in there...thanks!
umm please NO ! there will be terrible consequences if you do that !!
Originally Posted by BPVIP
pic from last night everything is finally in pic of the car full dump 0psi
why did you weld the bracket to the strut and not use the lock collars am i missing something ??
This is one of my biggest fears when I get airbags installed. Just curious, if you park somewhere with the block, do you get out and make sure you're not touching it before you release the air?
Its looks like it but its not welded to the collar. The bottom part is a threaded sleeve welded to the air bag plate, you can tell by looking at the threaded part. the goldish color is the JIC coilover the dark threaded part is actually over the JIC coilover and resting on the locking collars. Hope that makes sense...
Here are where the switches are =) had them in the ash tray but not enough room behind for air lines. More pics/update Friday didnt need that cig lighter anyways
