Is300 widebody build
My Name is Roy and i purchased my sport design is300 back in august 2010 follows I thought i would post my pics of the build on what i have done in the past year with my custom widebody....
![Name: IMG_1352-1.jpg
Size: 96.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430466d1501349535-is300-widebody-build-img_1352-1.jpg)
In purchasing the car i knew i wanted deep dish setup and wanted to set my is300 apart from most that i had seen at the time. After Looking on numerous Forums for some wheels i finally found some ssr viennas.
![Name: DSC05209.jpg
Size: 65.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430467d1501349535-is300-widebody-build-dsc05209.jpg)
18x10 +32 in the front and 18x12+38 in the rear!!!
So i get the wheels in and am very excited to see how the fitment it going to be and work is necessary. I try fit the wheels but the coils and lower arm wont allow me to...
I order 20mm spacers for the front and 27mm for the rear. TRY the fitment again and yessss success!
![Name: IMG_1681.jpg
Size: 112.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430468d1501349535-is300-widebody-build-img_1681.jpg)
![Name: IMG_1679.jpg
Size: 107.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430469d1501349535-is300-widebody-build-img_1679.jpg)
![Name: IMG_1677.jpg
Size: 70.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430470d1501349535-is300-widebody-build-img_1677.jpg)
and with the addition of the spacers the wheels stick out just about 3 inches all around... looking very messycan i must say.. hey i am so its ok right?
Along with wheels i was looking at kits and decided on a vertex kit. Called vertex and 3 months is what they told me... burn! I am impatient and did some more searching and found that vis made a replica kit instock. ahhh trust me i really wanted the authentic kit, but i knew that i may have to cut the kit and adjust it for the wider fitment so i said screw it and purchased it. Not much cheaper than vertex at about $1100 shipped
![Name: IMG_1725.jpg
Size: 69.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430471d1501349535-is300-widebody-build-img_1725.jpg)
So time for the widening process. I own a small paint and body shop here in austin tx, and have repaired some pretty mauled metal before but i was definitely nervous on performing this process. But here we goooo!
Grind the metal
![Name: IMG_1775.jpg
Size: 139.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430472d1501349535-is300-widebody-build-img_1775.jpg)
Make some cuts
![Name: IMG_1771.jpg
Size: 42.7 KB](https://www.clublexus.com/forums/attachments/build-threads/430473d1501349535-is300-widebody-build-img_1771.jpg)
and start to shape
![Name: IMG_1773.jpg
Size: 108.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430474d1501349535-is300-widebody-build-img_1773.jpg)
After a couple of hours
![Name: IMG_1788.jpg
Size: 77.8 KB](https://www.clublexus.com/forums/attachments/build-threads/430475d1501349535-is300-widebody-build-img_1788.jpg)
Some more work along with fitment of side skirt
![Name: IMG_1898.jpg
Size: 99.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430476d1501349535-is300-widebody-build-img_1898.jpg)
![Name: IMG_1900.jpg
Size: 41.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430477d1501349535-is300-widebody-build-img_1900.jpg)
With the wheel installed
![Name: IMG_1796.jpg
Size: 61.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430478d1501349535-is300-widebody-build-img_1796.jpg)
![Name: IMG_1794.jpg
Size: 44.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430479d1501349535-is300-widebody-build-img_1794.jpg)
I also bought some used coils off my.is, and look what came in!
![Name: IMG_1747.jpg
Size: 122.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430480d1501349535-is300-widebody-build-img_1747.jpg)
![Name: IMG_1745.jpg
Size: 124.7 KB](https://www.clublexus.com/forums/attachments/build-threads/430481d1501349535-is300-widebody-build-img_1745.jpg)
I mean really i cant even adjust these so rusted, the seller never responded to any of my messages either, what a douche! I sprayed some wd40 and the rings just shattered haha. i called tein and had some new rings sent out and will get these sandblasted here soon.
stock
![Name: IMG_1812.jpg
Size: 44.8 KB](https://www.clublexus.com/forums/attachments/build-threads/430482d1501349535-is300-widebody-build-img_1812.jpg)
Flared
![Name: IMG_1810.jpg
Size: 48.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430483d1501349535-is300-widebody-build-img_1810.jpg)
Sideskirt on!
Grind the metal
Make some cuts
and start to shape
stock
Flared
Sideskirt on!
![Name: IMG_1910.jpg
Size: 50.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430484d1501349535-is300-widebody-build-img_1910.jpg)
Now with the bumper installed, notice the flare extends past the vertex front.
![Name: IMG_1985.jpg
Size: 80.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430452d1501349535-is300-widebody-build-img_1985.jpg)
this is after i shaped and fiberglassed the flare, i then added a small amount of evercoat to smooth it out
![Name: IMG_2016.jpg
Size: 173.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430453d1501349535-is300-widebody-build-img_2016.jpg)
![Name: IMG_2012.jpg
Size: 181.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430454d1501349535-is300-widebody-build-img_2012.jpg)
![Name: IMG_2014.jpg
Size: 168.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430455d1501349535-is300-widebody-build-img_2014.jpg)
mock up of what needed to be built out of fiberglass
![Name: IMG_2271.jpg
Size: 92.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430456d1501349535-is300-widebody-build-img_2271.jpg)
![Name: IMG_2268.jpg
Size: 111.9 KB](https://www.clublexus.com/forums/attachments/build-threads/430457d1501349535-is300-widebody-build-img_2268.jpg)
and the finished product
![Name: IMG_2273.jpg
Size: 180.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430458d1501349535-is300-widebody-build-img_2273.jpg)
![Name: IMG_2277.jpg
Size: 110.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430459d1501349535-is300-widebody-build-img_2277.jpg)
Some may have seen an is250 on the forums... i also did the work on his... little refresher...
how she came in
![Name: IMG_4344.jpg
Size: 84.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430460d1501349535-is300-widebody-build-img_4344.jpg)
![Name: IMG_4346.jpg
Size: 87.8 KB](https://www.clublexus.com/forums/attachments/build-threads/430461d1501349535-is300-widebody-build-img_4346.jpg)
i tore her down
![Name: IMG_2382.jpg
Size: 87.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430462d1501349535-is300-widebody-build-img_2382.jpg)
and she left looking good!!
![Name: IMG_2414.jpg
Size: 32.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430463d1501349535-is300-widebody-build-img_2414.jpg)
![Name: IMG_2433.jpg
Size: 52.9 KB](https://www.clublexus.com/forums/attachments/build-threads/430464d1501349535-is300-widebody-build-img_2433.jpg)
how she came in
i tore her down
![Name: IMG_2429.jpg
Size: 43.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430465d1501349535-is300-widebody-build-img_2429.jpg)
Smoothed out the flares while also creating a small lip for the fenders to give it the oem look...
![Name: IMG_2510.jpg
Size: 36.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430431d1501349535-is300-widebody-build-img_2510.jpg)
![Name: IMG_2512.jpg
Size: 23.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430432d1501349535-is300-widebody-build-img_2512.jpg)
![Name: IMG_2514.jpg
Size: 50.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430433d1501349535-is300-widebody-build-img_2514.jpg)
pass side
![Name: IMG_2516.jpg
Size: 31.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430434d1501349535-is300-widebody-build-img_2516.jpg)
![Name: IMG_2518.jpg
Size: 35.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430435d1501349535-is300-widebody-build-img_2518.jpg)
Shaped smoothed rear panels along with a small lip
![Name: IMG_2541.jpg
Size: 35.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430436d1501349535-is300-widebody-build-img_2541.jpg)
![Name: IMG_2543.jpg
Size: 40.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430437d1501349535-is300-widebody-build-img_2543.jpg)
Also added the flare to the factory rear bumper
![Name: IMG_2545.jpg
Size: 35.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430438d1501349535-is300-widebody-build-img_2545.jpg)
![Name: IMG_2549.jpg
Size: 75.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430439d1501349535-is300-widebody-build-img_2549.jpg)
After about 10 more hrs i complete
-sanding and blocking the flares
-rear lip fitment and modification, since the rear lip is meant for a jdm rear
-Primed and ready for the final sanding stage before paint
![Name: IMG_2563.jpg
Size: 83.7 KB](https://www.clublexus.com/forums/attachments/build-threads/430440d1501349535-is300-widebody-build-img_2563.jpg)
![Name: IMG_2565.jpg
Size: 77.5 KB](https://www.clublexus.com/forums/attachments/build-threads/430441d1501349535-is300-widebody-build-img_2565.jpg)
![Name: IMG_2567.jpg
Size: 60.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430442d1501349535-is300-widebody-build-img_2567.jpg)
![Name: IMG_2569.jpg
Size: 52.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430443d1501349535-is300-widebody-build-img_2569.jpg)
![Name: IMG_2571.jpg
Size: 72.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430444d1501349535-is300-widebody-build-img_2571.jpg)
Almost there, there are some minor little pits that i need to fix along with one more block of the car and its paint time, the qtr panels and front fenders have about a 3 inch flare and my goal was for it to look as stock/ factory as possible and not like a crazy wide body, i'm not sure if its just me since i am used to seeing my car this way but i am pretty proud of the outcome. I have clocked about easily about 140 hrs in the body work, flaring, and welding process. Its been a tough road but i wouldn't have it any other way.
The final stages of blocking is set, Also decided to go for a molded rear lip, the double sided tape was not holding the lip on the rear bumper as tight as i wanted and kept sagging with the heat. Fitted the new jdm black chrome grill, it fits like a glove.... almost ready for paint.
![Name: IMG_3749.jpg
Size: 219.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430445d1501349535-is300-widebody-build-img_3749.jpg)
![Name: IMG_3754.jpg
Size: 225.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430446d1501349535-is300-widebody-build-img_3754.jpg)
![Name: IMG_3753.jpg
Size: 146.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430447d1501349535-is300-widebody-build-img_3753.jpg)
![Name: IMG_3755.jpg
Size: 211.8 KB](https://www.clublexus.com/forums/attachments/build-threads/430448d1501349535-is300-widebody-build-img_3755.jpg)
![Name: IMG_3756.jpg
Size: 227.5 KB](https://www.clublexus.com/forums/attachments/build-threads/430449d1501349535-is300-widebody-build-img_3756.jpg)
![Name: IMG_3750.jpg
Size: 174.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430450d1501349535-is300-widebody-build-img_3750.jpg)
pass side
![Name: IMG_3752.jpg
Size: 143.7 KB](https://www.clublexus.com/forums/attachments/build-threads/430451d1501349535-is300-widebody-build-img_3752.jpg)
Here is shot of the rear with my stock wheels to see how much pull on the rear quarter panel there actually is.
![Name: IMG_3760.jpg
Size: 137.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430412d1501349535-is300-widebody-build-img_3760.jpg)
![Name: IMG_3758.jpg
Size: 83.8 KB](https://www.clublexus.com/forums/attachments/build-threads/430413d1501349535-is300-widebody-build-img_3758.jpg)
![Name: IMG_3763.jpg
Size: 190.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430414d1501349535-is300-widebody-build-img_3763.jpg)
![Name: IMG_3762.jpg
Size: 135.9 KB](https://www.clublexus.com/forums/attachments/build-threads/430415d1501349535-is300-widebody-build-img_3762.jpg)
And now the rest of the car is done... i am waiting for my wheels to come back, vr is rebuilding them with a 6 inch rear and 4 inch front. Hope i can get them on and fitted by wekfest austin sept 30th
![Name: IMG_3777.jpg
Size: 159.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430416d1501349535-is300-widebody-build-img_3777.jpg)
![Name: IMG_3772-1.jpg
Size: 165.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430417d1501349535-is300-widebody-build-img_3772-1.jpg)
![Name: IMG_3771-1.jpg
Size: 221.3 KB](https://www.clublexus.com/forums/attachments/build-threads/430418d1501349535-is300-widebody-build-img_3771-1.jpg)
![Name: IMG_3773-1.jpg
Size: 222.9 KB](https://www.clublexus.com/forums/attachments/build-threads/430419d1501349535-is300-widebody-build-img_3773-1.jpg)
![Name: IMG_3774-1.jpg
Size: 229.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430420d1501349535-is300-widebody-build-img_3774-1.jpg)
![Name: IMG_3775.jpg
Size: 158.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430421d1501349535-is300-widebody-build-img_3775.jpg)
![Name: IMG_3770-1.jpg
Size: 214.0 KB](https://www.clublexus.com/forums/attachments/build-threads/430422d1501349535-is300-widebody-build-img_3770-1.jpg)
So in between drinking a large amounts of alcohol i actually got some work done.
Wetsanding,buffing and a last minute decision to smoke my taillights took most of my time and here are the results.When i get my wheels in i will tune the suspension just how i want and have some final shots, but this will do for now. Thanks for the feedback.
![Name: IMG_3782-1.jpg
Size: 120.1 KB](https://www.clublexus.com/forums/attachments/build-threads/430423d1501349535-is300-widebody-build-img_3782-1.jpg)
![Name: IMG_3784-1.jpg
Size: 107.6 KB](https://www.clublexus.com/forums/attachments/build-threads/430424d1501349535-is300-widebody-build-img_3784-1.jpg)
![Name: IMG_3785-1.jpg
Size: 166.7 KB](https://www.clublexus.com/forums/attachments/build-threads/430425d1501349535-is300-widebody-build-img_3785-1.jpg)
![Name: IMG_3787.jpg
Size: 119.2 KB](https://www.clublexus.com/forums/attachments/build-threads/430426d1501349535-is300-widebody-build-img_3787.jpg)
![Name: IMG_3789-1.jpg
Size: 111.9 KB](https://www.clublexus.com/forums/attachments/build-threads/430427d1501349535-is300-widebody-build-img_3789-1.jpg)
![Name: IMG_3788-1.jpg
Size: 137.7 KB](https://www.clublexus.com/forums/attachments/build-threads/430428d1501349535-is300-widebody-build-img_3788-1.jpg)
![Name: IMG_3791.jpg
Size: 265.9 KB](https://www.clublexus.com/forums/attachments/build-threads/430429d1501349535-is300-widebody-build-img_3791.jpg)
![Name: IMG_3796.jpg
Size: 269.4 KB](https://www.clublexus.com/forums/attachments/build-threads/430430d1501349535-is300-widebody-build-img_3796.jpg)
man you have a real talent my friend. I have seen some body work done and from what I can tell you really take pride in your work. If I didnt live in Fl I would be using you for any body work! lol
ahhh YOU did ATX250's brown paint.....your work is amazing!!! Great quality and done RIGHT!!! I gotta give it to you..It's awesome! When I saw the final pics but the silver wheels, I thought....he needs some chrome to make the grey jump out a bit...then BAMMMM FAT lips!!! some interior work and motor/stereo will get you something at Wek Fest. Good luck.
