Build Threads Details on Club Lexus SC owner vehicles
1993 Sc300 NA-T Build!!
Old 09-21-12, 05:53 AM
  #61
99SC42
99SC42's Avatar
Originally Posted by TOYJOETA
Sweet, any benifits to the usdm and maf vs the jdm and map other than being able to use 550's? Sorry for the hijack.
Ignition and fuel map iirc are also a little different .
I like map snsor setup because it's easier to deal with , plus i alot of people don't like the maf in front of the turbo.
I don't have any experience with maf sensor on boosted application, i always convert from maf to map
Old 09-23-12, 07:41 AM
  #62
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
It is definitely coming along man. Everything looks great...
Old 09-23-12, 11:59 PM
  #63
2jzforlife
2jzforlife's Avatar
Originally Posted by projectna
nice work man
Thanks
Originally Posted by Medic91x
I love the thread so far, that's a very clean sc300.
Is the XS downpipe you have you different from the one DM offers? It looks similar and has the same useless bungs that I have at the bottom of my downpipe. Just curious
Also, where did you source the manifold from and how was the quality and fitment?
The XSpower manifold and downpipe had great fitment. The downpipe i was able to bolt right on with a 1 inch adapter i made with two exhaust flanges
Awesome build, are you using the TT maf?
Thanks.. and yup TT maf
Originally Posted by Quicksc4
Yes because he is using a usdm tt box.
Op nice progress!
I am going to make some recommendation if you don't mind ..those coil wires are junk they come apart , i bought the same one and after 1 hour drive they were done, so i just got a brand new set from toyota.
If you want the toyota part number i'll give it to you.
Everything else looks amazing ! keep it up
Thanks really? The part number would be nice ill just go and order them just in case.. Thanks
The usdm is great for a 400-500hp setup since it uses the 550cc injectors while the jdm uses the 440cc injectors.. One thing i dont like is that it uses a maf and a map while jdm only uses map+iat
Originally Posted by 94_soarer
looking great bro
Thanks
Thanks
Old 09-24-12, 03:39 AM
  #64
food7373
food7373's Avatar
You're getting pretty close! Can't wait to see the dyno numbers...
Old 09-24-12, 05:38 AM
  #65
99SC42
99SC42's Avatar
Old 09-24-12, 08:17 AM
  #66
kez
kez's Avatar
Coming along looking good
Old 09-25-12, 11:01 PM
  #67
2jzforlife
2jzforlife's Avatar
Got my AEM wideband 02 sensor in and my AEM oil pressure sensor and below is a pic of the heated 4 wire o2 sensor that comes in the us TT mkiv 2jz supra
Old 09-25-12, 11:02 PM
  #68
2jzforlife
2jzforlife's Avatar
For those who were wondering.. This is how i got my downpipe bolted up to my stock mid pipe. I had to use two of these flanges and some longer bolts and worked great
Old 09-25-12, 11:03 PM
  #69
2jzforlife
2jzforlife's Avatar
Got my third AEM oil pressure gauge in and connected all working great.
Old 09-25-12, 11:05 PM
  #70
2jzforlife
2jzforlife's Avatar
BOV all mounted up and got a bigger oil catch tank instead of the ebay leaky crap tank
Old 09-25-12, 11:06 PM
  #71
2jzforlife
2jzforlife's Avatar
Got my TT maf sensor wired up and filter hooked back up still waiting for my turbo pressure sensor/ Map sensor.. But this is how she currently sits
Old 09-25-12, 11:12 PM
  #72
2jzforlife
2jzforlife's Avatar
Got my Front facing intake manifold made by Xspower and clubna-t. Honestly i love it so far.. Going to be picking up a q45 throttle body for it tomorrow and going to mount my stock tps sensor on the q45 using driftmotion's tps adaptor.
Old 09-26-12, 01:40 PM
  #73
Heyboss2JZ
Heyboss2JZ's Avatar
Awesome work!!
Old 09-26-12, 01:46 PM
  #74
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
What progress the last few days. Looks good man. I heard that the stock intake manifold supports more air by volume than any aftermarket. Is this true? I kinda think that is hard to believe due to so many people using aftermarket. Why would someone change it if it would not perform up to the specs?
What made you put the gauges in the woodgrain versus buying a a pillar post? Just curious, looks really good man.
  #75
food7373
food7373's Avatar
Great job man! Nice to see all the pictures! It's going to be well worth it when you are done!
Quick Reply: 1993 Sc300 NA-T Build!!
