Skid racing build
#241
I started working on my dash and switch panel I hope to have it complete along with the chassis harness this weekend.
I am going to work on putting new woodgrain on the whole upper trim piece. So it wont have and holes in it.
#243
The past 2 days I have been wiring my car and wish I would not have used a painless harness it turned in to a pain in the butt. They dont use relays in there fuse block and I dont like that. So I wired in relays and removed about 15 wires out of there harness. In short I should have just have made a fuse block my self.
I have the rear tails and fuel pump just need to wire my switch panel I made and headlight.
#244
So I took the car over to Elevens paint and fiber to have the body put into primer and have all the dents takin out. The car looks great all dents removed and primer all blocked out.
#245
#248
Everything is looking great! Wow.
*Have you thought about putting those Ebay clear lenses over the factory inner housings? Those Ebay lights are nottt the best quality as you'll probably see when you try to adjust them- and/or when the LEDs go out.- Especially considering all the quality parts it'd kinda be a shame! Tho I understand it's cheap to replace if you hit something drifting, but yeh.
By the way, are the wheel wells going to be left like that? If it's sturdy enough I might consider doing that same sort of thing vs. enclosed custom arches... hmm
#249
Ya the wheel wells are fine tue front have support of the tube add from the strut tower to the frame. The headlights are not my first choice but like you said easy to replace.
#251
#252
[QUOTE=2jzcoupe;8119186]The past 2 days I have been wiring my car and wish I would not have used a painless harness it turned in to a pain in the butt. They dont use relays in there fuse block and I dont like that. So I wired in relays and removed about 15 wires out of there harness. In short I should have just have made a fuse block my self.
okayy so im not so good with wiring and all but ive got some friends that are. and are planning on helping out. i have my 1j sc300 all stock last year basically and i ended up stripping it down for track use only like yourself. i took out pretty much all of the wiring besides the main engine harness. did you strip out all of the wiring also and then run a painless fuse block and push button start and fuel pump on a switch? im hoping to finish mine up asap but im looking for the easiest way wiring wise to get this thing back together and running. any info or help would be greatly appreciated considering i managed to miss this entire season of drifting
thank you
thank you
#254
[QUOTE=ppayne1201;8205034]
This car has zero of the stock harness and I used a painless kit that was the worst thing I did since I had to add relays for everything since they only use direct power for everything. My car has switches to control everything I did not use any stock switchs.
thank you
thank you
#255
[QUOTE=2jzcoupe;8207012]ahh well **** im back at point zero again lol.
