Skid racing build
#47
This week I have been spending some time fitting my kit with the help of my buddies at Elevens paint and fiber yes its a knock off yes I will blow it up and buy another knock off.
I went ahead and put my coils on and try and get them all adjusted
fitting the rear overs
#48
I will try and get my real camera out in the future sorry for the pics
here is a few of my rear firewall all done and welded in I still have a few area to seal up in the back hope to tackle that this weekend
#55
Oh what's your weight. Because I know xdc says over 3k must use 1.75". I wonder with my car stripped out if I will make it under 3k with cage. I really want to use 1.5 so much cheaper for the die I have a jd2 bender. I know the 1.5 die is 150 shipped and the 1.75"die is 450 for the one I want. What specs are your cage built for?
#56
1.5 .120 wall I think can be used over 3k pounds. I dont see my car being over 3200 pounds after removing everything luxury about the car and then removing sheet metal and tons of wiring.
#58
5.4.19 Roll Cage Tubing Sizes:
For the purposes of determining roll bar tubing sizes, vehicle weight is as raced,
but without fuel and driver. Note: There is an allowance of minus 0.010 inches
on all tubing thicknesses. Vehicles that previously competed in XDC or other
similar series prior to January 1
st
, 2011 with different roll cage tubing sizes will be
grandfathered in. Minimum tubing size for the roll cage is:
1501 - 2500 lbs.
1.500” x 0.095” Seamless Alloy (4130), Seamless mild steel (CDS
Mechanical) or DOM
2501 - 3000 lbs.
1.500” x 0.120” Seamless Alloy (4130), Seamless mild steel (CDS
Mechanical) or DOM
1.750” x 0.095” Seamless Alloy (4130), Seamless mild steel (CDS
Mechanical) or DOM
3001 - 4000 lbs.
1.750” x .120” Seamless Alloy (4130), Seamless mild steel (CDS
Mechanical) or DOM.
st
1501 - 2500 lbs.
Mechanical) or DOM
2501 - 3000 lbs.
Mechanical) or DOM
Mechanical) or DOM
3001 - 4000 lbs.
Mechanical) or DOM.
