Build Threads Details on Club Lexus LS400 owner vehicles
Dranom's LS400 Build
Old 05-11-13, 03:00 PM
  #106
Dranom
Dranom's Avatar
Originally Posted by PureDrifter
looking good dranom.
I'm still waiting for my elusive JP billet grill to pop up for sale somewhere
Thanks bro!
Yeah those JP billet grille looks nice but very hard to find
Old 05-20-13, 09:41 PM
  #107
Seize
Loves Snickerdoodles!
Seize's Avatar
Car looks fantastic! Love the color combo of the gold against the baroque red
Old 05-20-13, 10:32 PM
  #108
Sevenevez
Sevenevez's Avatar
whew, thats a good lookin LS Dranom
Old 05-21-13, 11:42 AM
  #109
sgv_bum
sgv_bum's Avatar
looking good bro ... i still haven't install my accuair sensor arms it look like a ***** to do. how much did you get those corner lights for?
Old 05-22-13, 07:06 AM
  #110
Dranom
Dranom's Avatar
Thanks bro! But might sell the wheels for a different set
Thanks!
Thanks johnny! Atleast you have the air on mines in pieces still
I might have time this friday to sort it out. I forgot how much i got the JDM corner light? I got it few months ago
Old 05-22-13, 07:35 PM
  #111
TaffyK20si
TaffyK20si's Avatar
Dang! Nice LS man! Thanks for the tips about YAJ! I'm gonna be on there looking at stuff constantly now lol
Old 05-22-13, 07:55 PM
  #112
Dranom
Dranom's Avatar
LOL! be careful it's addicting
Old 06-08-13, 08:08 PM
  #113
Dranom
Dranom's Avatar
Air Install
Accuair Power wire with 80amp fuse
Accuair E-level with height sensors
Accuair I-Level
Accuair Tough pad
UAS Aero sport on megan LP
4 Gal Aluminum tank
Air Zenith OB2 Compressor
So finally started to install my air suspension. This will be just a basic build with No fancy floors etc...
I just want it running and leak free. Thia is my first time installing air so bare with me
First off Big Thanks to Timmytool for the step by step from his thread
Anyways I ran the Accuair power wire with 80amp fuse through the fenders and into the firewall with the main harness. Also bolted the fuse on the side of the engine bay so it's secured and clean looking.
When making a hole on the rubber make sure you go through since it's like a double layer rubber. Having someone with small hands is a plus since it a tight fit once the wire is inside the cabin.
I ran the power wire and ignition wire on the side under the door sills
The Ignition wire was tapped on the CIG fuse so the compressor will only turn on when the Ignition is ON
Made a small notch for the wire on the fuse cover so it's easier to close and secure
Just like on timmy's thread I drilled a hole on the plastic to run the wires to the trunk
I have a extra Distribution block that I covered with red electrical tape and bolted to the wall to run the power wire on. Still gonna clean this up and put some heatshrink on
Tested everything and the compressor works and Accuair Touch pad lights up
Next is to figure out how to run my height sensor wires. Probably need to drill new holes for it
To Be Continued.......
Old 06-08-13, 08:32 PM
  #114
Dranom
Dranom's Avatar
*Reserved
Old 06-08-13, 11:34 PM
  #115
Shmee
Shmee's Avatar
Looks good man!
Interested to see the install with the accuair and e-level and how you mount the height sensors. That's the route I'm planning on once I sell my race car and spares!
Old 06-08-13, 11:49 PM
  #116
PureDrifter
BahHumBug
PureDrifter's Avatar
well this is interesting....
good luck! PM me if you need any help/questions about running wires/setup.
Old 06-09-13, 12:12 AM
  #117
Dranom
Dranom's Avatar
Originally Posted by Shmee
Looks good man!
I might have a extra set of accuair stuff if your interested..
Accuair Vu4 Manifold
Accuair E-level with touch pad(regular)
Accuair height sensors
$1500 for everything
will do boss! If you see any problems feel free to let me know.
Like I said im a noob at this stuff
Thanks!
Old 06-09-13, 09:22 AM
  #118
Shmee
Shmee's Avatar
Yeah I definitely might be interested in that. Would that be everything from the elevel system or is it missing stuff?
Old 06-11-13, 12:33 AM
  #119
HyperMKIV
HyperMKIV's Avatar
interesting build
can't wait to see more
Old 06-11-13, 11:03 AM
  #120
timmy0tool
timmy0tool's Avatar
glad i could help out man! PM me if you have any more questions.
as for the height sensor wiring, there are few existing holes next to the ABS sensor wiring that passes into the trunk area (covered by rubber grommets).
you can even use the same grommet as the ABS sensor wiring to pass the air lines or height sensor wiring. for example, here on my accord wagon, running 3/8" lines, i was able to push two air lines into the existing ABS grommet (top right).
Quick Reply: Dranom's LS400 Build
