Dranom's LS400 Build
#124
glad i could help out man! PM me if you have any more questions.
as for the height sensor wiring, there are few existing holes next to the ABS sensor wiring that passes into the trunk area (covered by rubber grommets).
you can even use the same grommet as the ABS sensor wiring to pass the air lines or height sensor wiring. for example, here on my accord wagon, running 3/8" lines, i was able to push two air lines into the existing ABS grommet (top right).
![](http://i27.photobucket.com/albums/c194/timmy0toole/Air%20Suspension/IMG_0514.jpg)
the height sensor plug won't fit existing pre drilled holes
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
I just drilled some new holes (1 1/2") and put some computer wire plugs for airlines and sensor wires
#125
sall good. drilling holes doesn't hurt
. be sure to use grommets to protect the wiring/airlines. i would think the connectors are removable on the height sensor wiring, or at least small enough to fit through factory holes.
take lots of pics when doing the height sensors, and their placement. very curious to see that!
#126
The LS looks perfect on meisters. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I wish I had the cash to spare to buy your wheels.
The plugs for the connectors are fairly large, and I think they're designed to be weather sealed (it has been a while since I've played with an accuair setup, so I might be wrong).
#130
So I kinda got delayed with my air install but hopefully i can install everything on monday. Changed my mind on some of the parts. Still debating on running leader lines upfront so we'll see
Anyways I got my hand on some LED tails and installed it the other day. I wished it was the sequential ones but oh well..
There's a plastic plug that covers the screws so just pry it off and you'll see it
![](http://i90.photobucket.com/albums/k275/dranom/Dranoms%20UCF20/IMG_6728_zps82c4dc44.jpg)
Dirty =(
![](http://i90.photobucket.com/albums/k275/dranom/Dranoms%20UCF20/IMG_6729_zpsb8dfa212.jpg)
Side by side
![](http://i90.photobucket.com/albums/k275/dranom/Dranoms%20UCF20/IMG_6732_zpsdb3bbe7a.jpg)
Close up
![](http://i90.photobucket.com/albums/k275/dranom/Dranoms%20UCF20/IMG_6731_zpse8df14b3.jpg)
Installed passengerside. I dig it
Dirty =(
Side by side
Close up
![](http://i90.photobucket.com/albums/k275/dranom/Dranoms%20UCF20/IMG_6735_zpsf285bdde.jpg)
