8052JZ's NA-T Build
#287
Finally found some free time to get at least something done.
Turbo installed, lines made, welded AN fittings to GTE valve covers and powder coated gloss black. The first pic has the drain line a little to long so I shortened it an inch or two. Second pic is with the shortened line.
BTW everyone should get AN wrenches, they make life so much easier when making AN lines. Paid 40 bucks for my set on fleebay and you don't have to worry about scratching the fitting using a crescent wrench and a vice.
#296
Not much of an update but my buddy Matt at High Flow Fuel hooked me up with E85 fuel line parts. Also got the Continental Flex Fuel sensor with harness from Paceperformance and some spark plugs.
Now that the house is almost done.. Ill be getting more time on the car
#297
Just put my order in at DM for the rest of the parts to get me back on the road.. trans rebuild, r154 DM and marlin crawler parts, couplers, IC pipes, clamps, hoses, IACV flange, etc etc... Should have plenty to do for the next couple weeks.... cant wait!
#298
I was wondering if putting the flex fuel sensor on the return is ok since the inlet outlet diameter is small. It doesn't seem like the right thing to do since you want to know the percentage before it gets to the rail but I'm running -8 feeds and I believe the inlet and outlet on that sensor is 3/8?
#299
#300
^^^^ what gerrb said and to this article from Haltech down below. BTW that's the same sensor as the continental sensor just re-branded and 10x the amount.
http://www.haltech.com/flex-fuel-sensor/
