8052JZ's NA-T Build
#365
Damn!!! Looks amazing i really like your dedication .
Yes you have to cut and reweld it i had to do the same.
I got this thing for black SCs now lol!
More pics and hurry up and get it done haha.
#366
Its really fun trying to keep the dirt off the black! Make sure your ready to wipe down the car every morning if you like to see no dirt and only shine lol
Hoping to get this thing done withn in the next month. its been way too damn long... but we all have to work and take care of family first.
#370
Got a few things done over the weekend but not much and ill get better pics during the day.
PS lines hooked with the DM hardline
Harness is all connected and secured
3.5" DM driveshaft installed
also got a few parts in that are awaiting install as well
Mizu Radiator (same company that makes Mishimoto rad)
Two Zirgo 14" rad fans
#371
805,
I'm going to copying your fuel system upgrade almost to a T. Can you post some pics of where you mounted your FPR? Also I know you posted a couple of pics of your filter with the flex fuel sensor but where exactly are they mounted in relation to the car?? I'm assuming drivers side rear but can't tell from pics.
Thanks,
Shane
Thanks,
Shane
#372
805,
Thanks,
Shane
Thanks,
Shane
The FPR is mounted on the drivers side closest to the fender using a bracket I made bolted to the Brake boost.
Both the Flex fuel sensor and Fuel Filter are on the drivers side up front almost in the engine bay. but not. Basically where the brake line T is that goes to the rear of the car. I used an already provided bolt hole to bolt on the that T the filter is on with the bracket I made. The flex fuel sensor is mounted right on the firewall using self taping screws right next to the filter.
The circle in Red is the bolt i used to mount the fuel filter and you can also see the the Flex fuel sensor mounted on the firewall where it starts to curve down.
And where the FPR is mounted. Used some aluminum plate made a few holes and bolted it down the brake booster
