Build Threads Details on Club Lexus SC owner vehicles
8052JZ's NA-T Build
Old 04-30-14, 02:09 PM
  #601
Ali SC3
Ali SC3's Avatar
Sounds like that 7m cps adjustment helped alot. Its idling great and looks like the o2 feedback is working like intended. Not hearing the occasional blip or drop in the idle which is what happens if the cps is not acting right or if you get a timing error, so that is def good news. Best to iron out all the small stuff before the tuner gets a hold of it or you may end up needing a retune which is never fun. I think you are basically there now.
Old 05-01-14, 05:49 PM
  #602
lilSCsteve
lilSCsteve's Avatar
Nice vid, she sounds really smooth! Diggin the gauge mod as well!
steve
Old 05-02-14, 08:07 AM
  #603
8052JZ
8052JZ's Avatar
^^ thanks I'm at the point where I am working out all the little details and some major to get the car 100% for the dyno. Right now, I need to removed the rear diff and adjust the back lash. I will probably rebuild it sense it will be taken apart anyways.
Old 05-05-14, 08:06 AM
  #604
8052JZ
8052JZ's Avatar
Diff is out checked back lash and its a bit off. Ordering parts from Curt today to get this thing rebuilt and should be good to go.
Old 05-06-14, 08:58 AM
  #605
Ali SC3
Ali SC3's Avatar
I think you got some yellow stuff on your diff there
You figure out how to adjust that stuff, still a bit mysterious to me.
Old 05-06-14, 12:11 PM
  #606
8052JZ
8052JZ's Avatar
I taking the diff to Coast Driveline and Gear to have them do it. I want this thing done and back on the car so I can get it tuned and enjoy the boost finally lol
Old 05-12-14, 07:54 AM
  #607
8052JZ
8052JZ's Avatar
Should be getting the parts today or tomorrow for the diff than its being dropped off to get rebuilt. I still don't know if the LSD is damaged or not. I wont know until the drive line shop takes a look at. If it is damaged, the TRD LSD has been on back order for the last 8 months so I will probably have to go with something else.
Modified a fan shroud to fit the 14" Efans. The came with 12" Fans but those are way to small. I used my plasma cutter and cut out the holes bigger to fit the 14" fans. I also drilled a few holes on the base of the fans so that air could circulate through out the shroud instead of the fan only pushing through where its mounted. Didn't take that many pics but here it is.
Old 05-12-14, 09:25 AM
  #608
gerrb
Super Moderator
gerrb's Avatar
Nice shroud Richard ! I wish I can weld good like you ..
Old 05-12-14, 09:28 AM
  #609
CatManD3W
CatManD3W's Avatar
What made you decide to not use the factory fan.....Alot of people say the electric fans dont provide as much cooling as OEM
Old 05-12-14, 10:02 AM
  #610
8052JZ
8052JZ's Avatar
Thanks Gerry!
CatManD3W,
If you have the right setup, Efans will do the job. I went with Efans because I wanted to run a 4" TB intake pipe and with the factory fan and shroud there's just not enough room for the 4" pipe.
Old 05-12-14, 11:46 AM
  #611
CatManD3W
CatManD3W's Avatar
Makes sense....I always thought to run two pushers on the front and two pullers on the back....Probably would be overkill but better safe then sorry
Old 05-12-14, 11:53 AM
  #612
8052JZ
8052JZ's Avatar
The problem with that is if you would run a puller on the back you would have to attached to the AC condenser because there is simply not enough room to put fans on the back of the rad.
Old 05-15-14, 08:19 AM
  #613
8052JZ
8052JZ's Avatar
Last night I rebuilt the 7m cps using the driftmotion kit as the oil seal was leaking. Took about 30 or so min to rebuild it.
And finally got the diff parts and the diff is now at the drive train shop. Hopefully everything goes smoothly and in the next week or so I can have it back on the car.
Old 05-21-14, 09:31 AM
  #614
8052JZ
8052JZ's Avatar
While I'm waiting for the diff, decided to get a line lock. Should have it on tonight. Also need to figure out how I want the momentary switch. Thinking about modifying the shift *** to have the button on top and have a rocker switch arm the system on and off just for safety reasons.
Old 05-21-14, 03:06 PM
  #615
97-SC300
97-SC300's Avatar
In for a diy on the line lock install please post lots of pics
Quick Reply: 8052JZ's NA-T Build
