8052JZ's NA-T Build
#1051
I used washers to space it out......and got new longer bolts from hardware store.....i.e better than the garbage they give you in that kit
#1052
The one thing CAN NOT DO is drive in the rain. I was an hour away from and it started to rain, which forced me to drive 45-55mph on the highway all the way because the car would not stay straight.
#1053
Do you know the length of the spacers you did? From your pics, you have the front higher and the rear of the seat a bit lower. How does that feel in the car compared to being even on the spacers? The floor of our car already has a slight slope but wonder how it feels with the additional slope of the seat.
#1054
Thanks, I saw the pics. I think I will make up a nice once piece spacer out of some flat iron stock or aluminum. I feel like the washer spacer deal will put to much strain on those 4 corners of the seat and not be as strong of a mount. With a one piece square spacer connecting all the corners together, the seat will be pretty solid and wont put as much pressure on those 4 corners possibly damaging the fiberglass over time.
As far as the rear I wanted it to be lower than the front just for personal preference..
I can get you measurements of what was needed to clear slider in the front.
You will also notice since the seat is fiberglass that they are not exactly perfectly flat on bottom side....and the spacing for bolt holes differs a little bit depending on how the mold went.
#1055
Very true with the washers....but I added more to the front higher so it would clear the slider....you will see what I am taking about when you start to install it.....
#1056
Steve
#1058
when you have a standalone you can have it adjust the boost controller by your speed mph, it helps with low traction situations at certain speeds. like lets say under 30-40mph you only want to run off your gate at 10-12 psi cause an more you just spin the tires, and then above that you want 18+ psi. you can set exactly what boost you want at what speed and the boost controller will do it on the fly. most people do it by speed on standalones even when setting all the speeds to one boost level.
#1059
Steve K.
#1061
I did see someone on SF start to make them but not sure how well they are made. Also not sure about VVTI heads. Might want to contact SAAD Racing about that.
#1062
Have you thought about the R888s? I have them on the Supra and love them. They are loud, but the performance trade off is worth it. We are making similar power, but Larry has 5 different maps for my car, all with boost by mph, and it is set up perfect for the R888s. No issues with traction, braking is great, and handling is outstanding too.
Steve
Steve
#1063
On a sad side note, after being at over 700hp for the last 2.5 something years driving it hard everyday, she decided to give out. Did a highway pull on the way home from work, limped it back to the driveway only to hear the motor ticking extremely loud. Not sure what happen but it sound like a valve might have lifted.
Sad but not really. Got tired of that 700 mark so its time to get the built motor in and shoot for that 1k mark
Crapy snapchat video, but you can get the idea of whats going on.
#1065
Its rod knock in deed. I've been getting the new motor ready to get swapped. I pulled the lower pans off along with the oil pump so it can be ported on the inside and a few other holes be opened up for better drainage. Ill post up pics later. Also ordered new seals and bolts from Toyota. A little over kill but its piece of mind for me.
